Question about GE Refrigerators
Model TBX21N1TMRWH bottom of fridge is flooding with defrost water, about once a week
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
  • 17 Answers
SOURCE: Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Posted on Dec 10, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Posted on Feb 07, 2009
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 26, 2009
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Oct 19, 2013 | Whirlpool Freezers
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Every time my Frigidaire Model number frs26znh defrosts, water runs out of fridge door. of course, the pan in bottom of fridge is full of ice. water has not been connected for 6 weeks
Your Defrost drain Plug is clogged or kinked.
Check the tube from the freezer to the fridge, make sure it's connected, then pull out your drawers in the bottom of the fridge and clear your drain hole..
Mar 11, 2010 | Refrigerators
Flooding when freezer defrosts
Make sure the refrigerator is level and the drain tube is not clogged. This is the most common cause of water pooling.
Jul 29, 2009 | Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Water leaking into fridge
When your frig defrosts the water should go outside to the pan on bottom but it ain't cause the drain is stopped up. So the water just floods the ice box. Solution: Clear dat popcycle paper clogged drain up . Use some hot water to flush out dat drain.
Apr 10, 2009 | Refrigerators
Water drips from bottom of fridge. It happens
look in the bottom of the inside of the freezer, you probably will see ice buildup.You have to clear the drain which is stopped up at the bottom of the panel that covers the freezer evaporator.Every 8 hours the drain receives water from the auto defrost and needs to go in the drain, if drain is stopped up it freezes and eventually runs out the front
Mar 25, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
