DVD Shrink 3.2 Manual - Computers & Internet
Dvdfab registration key
Its illegal for anyone to provide serial keys for programs that have retail values set on them its Pirating
There are lots of freeware alternatives on the internet
fab dvd free
http://www.all-freeware.com/details/187648/dvdfab-gold.html
or
http://www.softpedia.com/get/CD-DVD-Tools/CD-DVD-Rip-Other-Tools/DVD-Shrink.shtml
DVD Shrink and DVD Decrypter are two programs that can be used to backup DVDs.
DVD Shrink reduces dual-layer DVDs in size so that they fit on single, blank DVD media.
DVD Decrypter is used to burn that file to disc after the video has been authored in DVD Shrink.
Open DVD Shrink, click "Full Disc" on the toolbar, then insert your DVD into the disc drive.
Click "Open Disc," then select the DVD drive, and click "OK."
Click "Main Movie," then remove any "Audio" or "Subpicture" (subtitle) streams that you don't need by disabling the tick boxes.
Click the "Extras," and decide if you want to remove any.
If you do, set the "Video" drop-down menu to "Still Image."
Click "Backup" then select "Create an ISO image" from the "Select backup target" drop-down menu.
Select "Browse" and then choose a temporary location for your ISO image to be stored.
Click "Quality Settings," and make sure "Compress video with high..." is selected.
Click "OK." Close DVD Shrink when the ISO image has been created.
Open DVD Decrypter, click "Mode," then "ISO," then "Write W."
Click the folder icon and locate the ISO created with DVD Shrink. Insert a blank DVD, and then click the burn button in the bottom-left.
You will now have backed up your home movie DVD.
Oct 13, 2013 | Computers & Internet
Tip
The Easiest Way to Use DVD Shrink
<b>DVD</b> <b>Shrink</b> is a freeware DVD transcoder program for Microsoft Windows that uses a DVD ripper to back up DVD movies. The final versions are 3.2.0.15 (english) and 3.2.0.16 (german), all other versions like DVD Shrink 2010 are scams. As commercially-released video DVDs are typically dual layer one of DVD Shrink's functions is to process the video into lesser quality and/or discard extra content such as foreign-language soundtracks so as to fit on a single layer (4.7 GB) DVD.<br /><br />DVD Shrink is freeware, and it is only to be used to create backup copies of DVDs you already own. It is illegal to make copies of rented or borrowed DVDs, or to copy them and sell them for profit. The reason we need DVD Shrink is because a regular DVD movie doesn't fit on the average 4.7gig size DVD disc, we <b>use</b> DVD Shrink to cut the contents down to size as to fit on the disk.<br /><br />This article will provide you <b>how</b> can you use DVD Shrink to copy DVD movies step by step. All you need is a DVD Shrink software and you will be able to store and duplicate all your DVD discs.<br />To use DVD Shrink, Things you will need:<br />* DVD Shrink program <br />* A DVD movie to backup<br />* DVD blank disc<br /><br />Guide: How to Use DVD Shrink 3.2 <br /><br />Step 1. Start the DVD Shrink Program and choose Open Disc from the menu above. <br /><br />Step 2. A box will appear. Choose which DVD drive your disk is in. Mine is in F: drive. The name of the disk will show up in brackets. In this case it is called NEW. <br /><br />Step 3. Press OK. It will read the DVD.<br /><img src="remote_image20110803-18141-1qmdivp.gif" /><br />Step 4. Shrink DVD size.<br />1) A breakdown of the movie will be displayed in the right hand column.<br />2) You cannot fit all this on your blank dvd so now press Re-author.<br />3) In the right column there will be a heading called Main movie. There will be a file under this heading. Drag this to the left column. The file size is usually more than 4,700mb and has to be compressed.<br /> <img src="remote_image20110803-18141-17xn34v.gif" /><br />Step 5. Click on the "Backup" icon. This is where you will choose a folder for your ripped files. Once you make a folder, make sure the box is checked next to "Create VIDEO_TS and AUDIO_TS subfolders" and click "OK".<br /> <img src="remote_image20110803-18141-sc8anv.gif" /><br />The movie will now play quickly in the viewing box, and you will see the progression of the rip. Once the rip is complete, the movie can be burned to a DVD-R automatically via DVD Shrink using NERO. Or if you have different DVD-burning software, you can open that manually and burn the ripped files as you normally would.<br /><br />Here we also recommend you the best DVD Copy software, 1CLICK DVD COPY PRO, which is a fast, easy-to-use, full featured program for copying DVD movies onto DVD discs. With 1CLICK DVD COPY - PRO, you can make a perfect copy with just one click. You can free download DVD Shrink via the link below:<br /><br />Tags: how to use dvd shrink,how to use dvd shrink 3.2,how to use dvd shrink to burn a dvd,dvd shrink free download,free dvd shrink,shrink dvd software<br /><br />Related Resources: <br /> <p><span><a href="http://www.dvdcopymac.org/burn-dvd/burn-movies-to-dvd-on-mac.html"><span>burn movies to dvd on mac</span></a>,</span><span> </span><span><a href="http://www.dvdcopymac.org/">dvd copy mac</a>, <a href="http://www.dvdcopymac.org/resource/free-dvd-copy.html">dvd copy freeware</a>,<a href="http://www.dvdcopymac.org/burn-dvd/convert-burn-m4v-to-dvd.html"> m4v to dvd</a>, <a href="http://www.dvdcopymac.org/guide/how-do-you-copy-a-dvd-in-windows-7.html">copy dvd in windows 7</a></span><br />
on Aug 03, 2011 | Computers & Internet
Hi: I just purchased an LG External multimedia burner, Model GE24. DVD Shrink on my computer is not recognizing the burner although other programs on the computer are. Can you please tell me how I can...
Unfortunately, DVD Shrink probably does not support your LG external media burner. Some programs are built just for certain CD/DVD drives. You can probably find another program similar to DVD Shrink for free online.
Jun 01, 2011 | Computers & Internet
Dvd shrink manuel
Hello wqaka ...
DVD shrink is freeware software and there is an online manual which hopefully helps you in regards to usage,
http://www.cdrinfo.com/sections/reviews/Print.aspx?ArticleId=8973
Sep 27, 2010 | Computers & Internet
How to convert dvd +r to dvd -r
Use DVD Shrink & Nero Burning Rom
1. Put the DVD +R in your computer's DVD burner drive
2. Open DVD Shrink
3. With 'Full Disc' checked, click 'Open Disc' button.
4. Choose settings as required.
5. After it does the quick preview, click 'Backup'
6. When it prompts you to insert a DVD insert a DVD-R
7. Close the dvd DVD drive.
8. When done, enjoy the movie.
Sep 27, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
Hi i am using vista, and am using dvd shrink 3.2 version to burn dvd discs i open my disc in dvd shrink then back up in dvd shrink to file created in documents, then dvd drive ejects disk and asks for...
you must remove the region lock off the DVD image you're trying to burn make it region free. your DVD player might have locks on which DVD regions you can play, your DVD writer doesn't come with a region lock that's why you're able to play the disc
Sep 21, 2009 | Ritek /RIDATA DRD+4716-RDSM50 16X DVD+R...
DVD Shrink
Try Downloading Media Ver. 11 from microsoft web site
Mar 27, 2008 | Computers & Internet
Can't burn movies onto dvd
in the software that u use to burn dvd...may be nero or roxio turn the dvd option on or select the dvd burning option.......u cannot use the xp writing sotware to burn dvds
Jan 01, 2008 | Pioneer DVR-112DSV DVD+RW Burner
Shrink-it
Are you talking about DVD Shrink? Actually it is quite simple..
First you open the DVD from the menu list, and it will run through a process of loading the DVD movie.
Then you decide if you wish to extract all the languages. If not, the compression will be less, and the quality better. Just uncheck the languages you do not need.
Then, click the Backup Button. A wizard will come up and you decide where you wish to save you movie. It will compress the movie and save it so you can burn it later. Or, you can burn it right then to another DVD (although I would prefer to do this separately.)
Now, I do not use Shrink anymore, as many protections that the new movies have cannot be broken, and Shrink will not work on them anymore.
Dec 04, 2007 | Computers & Internet
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
