Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Am having trouble charging my new power weelchair,I charged it for 24 hours and its still not turning on,I have a jazzy power weelchair program#DWR1111H035
  • 692 Answers
Well the problem is that the batteries are not connected correctly or the joystick is disconnected or something isn't right with the power supply(batteries). You should never charge the chair more than 18 hours. If it doesn't charge after that many hours there is a problem that continuous charging won't help. Since it is a new chair I would contact your provider where you bought the chair and have them come out to repair it. It is under warranty and its their responsibility to fix it I wouldn't let them get by with offering some lame excuse as to they're not able to fix. If all else fails contact Pride Mobility @ 1-800-800-8586 and tell them of your problem and demand repair.
Posted on Oct 03, 2010
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
I need 24 volt interstate batteries for my jazzy power chair. How much are 2 of them?
Well you don't need a 24 volt battery you will need 2 12 volt batteries for a total of 24 volts Contact any local Battery distributor or Interstate battery dealer. You will need 2 U1 sealed AGM or Gel cell batteries and the cost will be $175.00 to $218.00 for 2 batteries. After installing the new batteries be sure to charge before use and then charge every nite for the next 20 days. If you use the chair daily charge overnite If you don't use it daily always store fully charged and charge at least once a week Hope this helps you
Apr 03, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Hi when i charge my powered weelchair should be with power on or not?
When you charge your power wheelchair the power chair should be off. First of all, the charger will charge the chair without the power chair being on, since the charger works independently from the chair electronics. The chair electronics when they are on will drain a small amount of power and theoretically the batteries will take longer to charge.
Also, as with any electronic device or appliance it should be shut off when not in use for safety, longevity of the components, and conservation. There is no danger of the chair being driven off while the charger is plugged in because all power chairs have a built in safety feature disabling the chair when it is being charged. Hope this helps.
Nov 26, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
Charger shuts off before battery is fully charged
The batteries may have bad cells that will not allow a full charge. This can happen if the scooter has been stored for a while or if the charger has remained connected 24-7 for a long time.
Try replacing the batteries; cycle them 1-2 times to ensure they will take a full charge. (This means run the battery down into the red before you put it on the charger for 8-12 hours.)
Oct 10, 2010 | Pride Jazzy 1103 Ultra Standard Power...
A few months ago, I got 2 new batteries for my Jazzy and the first month everything was fine. Lately the batteries have been losing power abnormally fast. We were told to keep the chair plugged in at all...
Jeff WRONG!!!!!! I would demand that the dealer give you new batteries (they should be under a six month warranty anyway) You are to NEVER repeat NEVER leave the charger or chair plugged in all the time. The most you should ever have to charge the batteries is overnite or 12 hours. Never leave the charger plugged into the chair more than 24 hours. Doing so might even void the warranty. Tell that dealer or however told you that to take a hike or at least know what they are talking about. Have them read an owners manual (if they can read) under care and use of batteries Geez it just upsets me to have people give out such bad information to their customers. Now the batteries need to be replaced and when you get new ones charge them before you use the chair then charge then everynight if you use the chair daily if you don't use it daily make sure it is fully charged when you put it up and at least once week (if idle that long). I would recommend using your chair daily for a little while to run the batteries down some and then charging overnite for the first 20 days that you have the new batteries this will break them in. Hope this helps and sorry for the rant
Sep 25, 2010 | Jet Health & Beauty
I have a hand me down Jazzy Pride model 1121, which seems to be in excellent condition, other then the following problem. Brought it home and charged it for 24 hours. Powered up and would only turn to...
JRH, you didn't say if you put new batteries in the chair. If not some of your problem could be the batteries The lights on the joystick will blink a certain number of times to give you a "fault code" Use this code to determine the error. If after you rode the chair out of freewheel then the motor connection is not the problem. I'm guessing the batteries are the problem. Hope this helps
Aug 20, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
Nov 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Battery won't charge
First make sure that all the connections are tight. Then have the batteries load tested.
Mar 19, 2009 | Electric Jazzy 1115 Power Wheelchair
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
132 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
