Question about Kenmore Refrigerators
I have a Kenmore Refrigerator #253.74882400 It was working fine last week I moved it into the garage. Down 1 step. Did not abuse it. Now the frezzor works fine but the refrigerator is at 60 no matter where I set the control, I am allowing 24 hrs ever time I try to re set it. Any suggestions. Fan appears to be working and I cleaned out the coils with a wet vac. Jon
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 1314 Answers
SOURCE: Refrigerator won't get colder than 45 degrees/ Freezer side is working fine
the fridge thermostat is not a true thermostat it controls a damper door the freezer thermostat runs the compressor in order for your refrigerators to reach the proper temp the freezer should be about -8 to-10 set your freezer thermostat lower and see if it gets lower .at the mid point setting it should be about -8 not 6 you may have a problem with its thermostat or a leak in your system reply to me tomorrow and tell me if lowering the freezer thermostat help we want it about -8or-10 and the best way to check your refrigerator temp is put a glass of water in it and stick your thermometer in it and if need be you can e mail me at b4829@yahoo.com just referance your promblem
Posted on Jun 03, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
  • 5 Answers
SOURCE: My KitchenAid KBRS22K bottom mount refrigerator is
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
Posted on May 20, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
I have a Kenmore Cold Spot Side By Side Refrigerator/Freezer 106.52572202. The Refrigerator/Freezer was working fine until we moved it to the garage. We can hear the compressor working, but now the...
G'day - look to see if the unit has a cooling fan on the condenser - sometimes when you move a cabinet the hand truck can push up under the cabinet and jam the fan blade - or the tubing under the cabinet has been damaged
Sep 25, 2013 | Kenmore Refrigerators
We moved our side-by-side Kenmore from the kitchen to the garage yesterday and now it won't cool down. It was working fine before that. The compressor is running but is warm. We tried leveling it and...
hoe cold is it in the garrage?if it's cold wait till it gets warmer and it will work again or you could have knocked a wire off or damaged it somehow but it might just be to cold in the garrage.
Apr 12, 2011 | Kenmore Side by Side Refrigerator
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore refrigerator model 106 will not cool fridge or freezer
is your refridge leveled if not level it and stable. Try turn it off for a couples of hours and then put it back. does the refridge move a lot when u open it fix this refridge doesn't has to be moving when opening when on and moving this agitates the freon creates more pressure so it has a pressure switch and turns off the compressor to protect it from over or under pressure
Jul 24, 2009 | Kenmore Refrigerators
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Refrigerator not cool enough in garage.
if the unit is not in an area that falls below 65 degrees f then he is wrong, if the unit is in an 80 degree envorment then there is a problem with the unit possible sealed system leak 1st i would check, second a defrosting issue third fans running
unit can be serviced in the garage, the tech is incorrect
May 27, 2008 | Kenmore 60721 Refrigerator
Kenmore 77563 Installed last week and freezer defrosted all the food
The refrigerator & freezer operate using the same system. One system. Your still covered by the warranty and I would suggest calling the installers or store from which it was purchased. The problem may be a faulty fan switch .
Apr 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 795.7519
Either you have accidently left the door open at some time in the last few weeks or you have a faulty defrost sensor, initially turn off defrost freezer over night with doors open, turn on following day, unit should start to work within 12 to 24hrs, other wise replace defrost sensor but still deforst. Regards Advisor
Aug 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
