Question about KitchenAid Microwave Ovens
Hi. The microwave oven (KEMC308KSS01) shows the error message "DOOR" when attempting to start the microwave. I've checked the 20 amp bus fuse and it's fine (reads 0.3 ohms across the terminals. I understand that there is also a 15 amp line fuse. Is this accessed from the back of the microwave? Any other suggestions would be welcomed. Thanks.
SOURCE: Whirlpool microwave/oven model RM286PXV3
I have a 13yr old above-range oven which quit when my wife cooked food in an aluminized foil wrapper (a small fire ensued!). This oven has 3 thermal protection units, on the magnetron, the chassis and on top of the food cavity. This last one had failed open, and since it's in series with the magnetron thermal protection unit and the main relay, nothing would work. MAT electronics sell the units for less than $4, but my problem now is to pick one with the appropriate temperature cut-off. They range from 200 to 300F.
Posted on Nov 18, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Fuses keep blowing out
In case it's still helpful, I'll inject a little sanity into the replies.
If the fuse blows as soon as you hit Start, it's probably a shorted high-voltage capacitor. That's usually economical to repair.
If the fuse blows a few seconds after you hit Start, it's probably a shorting high-voltage transformer. That's usually not economical to repair.
It's not radiation (non-ionizing RF by the way) that's the hazard, it's the voltages.
Posted on Nov 05, 2007
SOURCE: LG MS-2143RSL MICROWAVE OVENT NO HEAT
hi i am suggesting that it is probably the magy as the res to grndis a bit low and therefore loading the sec supply down , just a thought
cheers grant
Posted on Oct 23, 2008
  • 3 Answers
SOURCE: Microwave oven blowing 20 amp ceramic fuse
Chances are if the varistor fails, it fails drastically causing a short circuit across the supply. It will sit across the supply (it will look like a thick ceramic capacitor) and you can check for continuity after isolating that at one end. If it shows low resistance (it should show almost open circuit with a Digital meter), replace it.
It need not be the culprit. If you are familiar working with High voltage circuits ( they are lethal inside a microwave ovens as the current capability is high here), you can discharge the doubler capacitor and isolate the high voltage diode to check for shorts in the HT area.
Posted on Mar 18, 2009
espressonist
  • 1711 Answers
SOURCE: How do you change the spirngbars on the microwave
We have here a video on how to remove door for replacing door hinges if it have any small diferences in model we belive is better than any written istructions. We have also the link for parts diagram of your actual model for additional guidance and also for a reference if you need to rder directly any parts.
Posted on Aug 11, 2011
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Microwave door warning light
If this is a built-in wall oven with microwave on top, it is probably the 20-amp fuse located above the microwave. It is wired in series with 1 of the door switches, hence the "door" message. The only problem is that you have to pull out the microwave oven (at least part-way) to be able to get to that fuse.
Dec 08, 2013 | Kenmore Microwave Ovens
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
The 20 amp power fuse blows every time i start the mircowave oven?
The oven probably has a bad interlock monitor switch, one of several switches in a microwave that are operated by the door latches. The switch is wired so the fuse will blow if you try to run the oven with the door open, and it isn't operating properly when you close the door. As soon as the oven kicks on the power to the magnetron tube, the microwave source, the fuse blows. The switch may have been damaged if the door was slammed, or it's just a mechanical failure. It's not an expensive part, but any microwave repair involving the door should be done by a professional because of safety concerns, so you will have some labor cost to add in. It shouldn't cost as much as a new oven to make this repair, though, so it's probably worth fixing.
Jan 13, 2011 | Hotpoint Microwave Ovens
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
I have a microwave oven (over the range) panasonic nnp295sf, it is having a problem that whenever I turn to start microwave on the bus fuse is burnt! when I put a new on everything works, except when I...
I presume you mean the fuse within the microwave.
If it is doing that, firstly check the door switches, if there is no problem then check the diode and capacitor supplying the magnetron. BEWARE, THERE ARE LETHAL VOLTAGES AT THAT POINT!!!
I suspect there will be a problem with the door switches.
Nov 01, 2010 | Panasonic NN-P295SF Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Just quit. No power, no display....nothing
    there are several possible causes, check voltage at outlet
    check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
    Sep 10, 2009 | Samsung MS1040BB Microwave Oven
    Mar 18, 2009 | Microwave Ovens
    Microwave Ovens Logo
    71 people viewed this question
    Top KitchenAid Microwave Ovens Experts
    William Miller
    William Miller
    Stu Ungar
    Darial Jr Lasaria
    Darial Jr Lasaria
    Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
