Help please, hardware monitor found an error
Hi benimur, how's it going ?
i have a problem wondering if ya can help me out? here is my problem...
every time i try to burn a dvd the computer shuts off and restarts and says
harware monitor found an error .enter power setup menu for details. press f1 to coutinue or delete to enter set up. i hit delete to enter set up to check the problem nothing is in red at all.mb temp 29 c/84 f cpu temp is 69 c/156f
cpu fan speed is 2860rpm. and all the volts are good. this is a new power supply replaced a month ago, and just wipe't my hard drive clean and reinstalled windows xp. this only happens when i try to burn a dvd ? any help would be greatly app. thank you
    Brigadier General:
  • 6,966 Answers
Hi havinthangs,
Have you tried ignoring the monitor error, that is pressing F1?
Additionally, you can try, use a separate power connector for the DVD drive not piggybacked to the one used by the HD. If your drives are SATA, double check on the power adapter. If your DVD is external and USB connected, check its own power supply. Further you may want to un-check the Auto Power OFF in Power Management for USBs.
If you think the problem is PSU related, you can try lowering your BIOS/CMOS settings down to Default and not Optimized.
Of course the next best try would be to use a another PSU preferably with a higher wattage.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 27, 2008
My HP vs19e monitor is displaying a flashing screen with lines. When I reboot it does the same thing.
Hi
Thank you for your query
Please try the following
1) Degauss the monitor- this can be found when you cycle through the menu options in your monitor
2) Please try the monitor in another PC to rule out VGA card issue
3) If there is a sepearte VGA lead going from the monitor to the back of the PC, please replace this
If the above 3 fails then unfortunatley it is a hardware fault, it may be prudent for you to replace rather than repair
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
Feb 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Dragon NaturallySpeaking 9 preferred will not work, Microsoft Excel
i do not understand your problem, can you please reexplain
Nov 29, 2007 | Computers & Internet
My hardware monitor found an error how do i fix this.
Hi:
Usually the hardware monitor is trying to tell you something, like a fan is failing or something is getting too hot. You need to open the hardware monitor page and see what the actual error is. On boot up, you either hit Delete key or F1 and then tab over to the hardware monitor page.
Nov 19, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Hardware monitor found an error enter power setup menu for detail
some error happen in your electrical pal, go to bios monitor the voltage or you can disable bios to monitoring voltage 5+ 12+
May 10, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Update on SC430 Sat Nav and TV conversion
Appreciate the direct "Ask Me".
Actually I made a follow just last night to robotek (Australia). Unfortunately nothing to report. You might be interested to view yourself the discussion and pls feel free to join the Lounge discussion here on a possible source of an Australian version of the SatNav/TV. Incidentally, roboteks email address is likewise posted there should you wish to send him additional information/request.
Cheers.
Benimur
Jan 31, 2009 | Car Audio & Video
Diagnosis: Lack of P.S.U. fan speed report indicates P.S.U. fan sensor damaged by overheating. This was caused by cooling fin blockage since the Sony design on this model cools the C.P.U. THROUGH the P.S.U.
Expert level fix: Remove P.S.U. Remove C.P.U. fan and vacuum. Remove C.P.U. cooling fins from C.P.U. and cooling fan mounts from fin box, vacuum. Reassemble C.P.U cooling system. Replace P.S.U. with O.E.M. part only since in this case it is proprietary to the unit.
Jul 31, 2008 | Computers & Internet
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it...
where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
May 31, 2008 | Toshiba Computers & Internet
Help please , hardware monitor found error
First, try by reinstalling Nero 7. If that doesnt work, it could be that your graphics driver does not have enough built in memory, and you will probably need to replace that. You could try installing the latest version of the driver for your graphics card first..
How much RAM do you have on your system? 128MB should be fine, but I recommend at least 512 MB installed.
Check these first and let me know how it goes..
May 26, 2008 | Computers & Internet
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Computers & Internet Logo
342 people viewed this question
David Payne
David Payne
