Question about iLO (2 GB) MP3 Player
Display "fried". No, literately, its fried.
I have an ilo mp3 1gb player, and for some reason, when i reinserted my battery back into my player, something inside the display fried, and now half the screen has a round scorch mark. Can this be fixed, or am i going to have to buy another one?
BTW, I can still play music, use the menu, exc., its just that i cannot see the system information.
  • 8,596 Answers
May need replacing, but
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 26, 2008
Flash error ,back up data and format the player
it keeps saying format the player and back up the dta
Sep 04, 2008 | iLO (2 GB) MP3 Player
Tip
Howdy, Doc; I was wondering if you've got any more help to give an iLO owner. A...
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
on Dec 01, 2008 | iLO (2 GB) MP3 Player
ILO 2GB player
This is, literally, the worst mp3 player ever made. There is no firmware update, formatting ruins it, and there is no support. But, you can try this as a last ditch effort:
Jun 25, 2008 | iLO MP3 Player
Mp3 player
Just try to reinsert the batteries and have chk whether u find a hold unhold button on it if u find it just slide it to the opposite side and then give it a try
May 27, 2008 | iLO (2 GB) MP3 Player
Problem trying to use usb cord to sync music to ilo mp3 player
May 26, 2008 | iLO (2 GB) MP3 Player
Wont' turn on
HI
Ilo Mp3 Player is weak in Power button so many people get same problem open the case and reinsert the power button still not working, change the rupper piece under the power switch
Bye Take Care
Apr 15, 2008 | iLO (2 GB) MP3 Player
ILo wont power up
i did the same thing and its still not working
i still need help
its just spazz ing out on me...
Jan 04, 2008 | iLO (2 GB) MP3 Player
ILO does not list all songs.
switch to mtp mode or auto, and make sure the songs are in the correct format
Nov 05, 2007 | iLO (2 GB) MP3 Player
MY ilo mp3 player will not start unless it is connected to a computer.
i fixed one recently that wouldnt turn on like yours, a part on the inside broke off and i resoldered it. if you dont mind, you might open it and have a friend whose good with electronics look around and see if anything is loose, disconnected, fried
Sep 30, 2007 | iLO (2 GB) MP3 Player
My player won't play music anymore.
I'm having the exact same problem with this player. I noticed a problem with the player a few days prior to it freezing up. The player would constantly cycle through the "searching" and "sorting" files process but would not complete it. Now it does nothing put display the ilo logo.After reading other reviews on this site I have decided to see if Walmart will take it back. I highly advise anyone who thinks about buying this product not to do so. It may seem like a bargain in the beginning but it is throwing money away.My player worked for less than 2 months.
Jun 29, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
32 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
