Question about RCA WSP150 Main / Stereo Speaker
No power light on transmitter. Measured correct voltage at power-in.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 11 Answers
The light does NOT stay on .....because it was not designed to.....takes INCOMING SOUNDwith the transmitter plugged into the sound source to make the light stay on......
Posted on Feb 02, 2012
BAD REPLACEMENT POWER SUPPLY
quite possibly have defective panel, since you have replaced X,Y & buffers.
Jan 30, 2015 | RCA 42PA30RQ 42 Class Plasma TV - 1024 x...
Cant get video sender remote control to work consistantly. sometimes 2 red lights appear on receiver remote control window and this is when the remote wont work. when only 1 light appears it works ok
Check the voltage from the power supply incorrect voltage will not power your device correctly therefore it seems not to b getting enough power so that's why only one light lights up or the unit itself has a circuit board short and needs replacement ..
Feb 24, 2014 | OEM Systems 5.8GHz Wireless Audio Video...
Transmitter Frequency alignment
look I'm going to tell you now. If you have no idea where to measure the voltage then you shouldn't be playing with that radio. First ,you need a scope,a frequency counter,a distortion meter,a signal generator,a watt meter,a voltmeter,a sinad meter and patience. If you have none of these then don't mess with it.
Jan 17, 2014 | Galaxy Radios Dx-949 40-channel Ssb Cb...
Asus aspire one d150-1bk dead, no lights, no sounds, nothing hapens. I measured the power of the charger and indicates 19v when is not connected but when I conect it to the laptop only had 0.8v. Witch...
Try removing the battery then connect the power and see if it turn on without the battery. Otherwise I suspect a bad power board inside the computer.... most of the time if the adapter is giving the correct voltage before plugging it in... it could indicate a problem if the voltage is then lower after plugging it in however unlikely... although it would be aworth making sure you have the right power adaptor for your computer
Oct 11, 2013 | Computers & Internet
The light is green on charger but the controls will not light up unless it is plugged in
When the charger light stays green when you plug it in it means the charger is not actually charging. Either the batteries are bad and will not take a charge anymore or the charger is not operating correctly. It sounds more like a battery issue. The battery voltage needs to be measured on each battery with a volt meter. If the voltage is less than 10 volts on either battery they both will need to be replaced.
Sep 26, 2013 | Electric Jazzy 1115 Power Wheelchair
Why is it displaying sc300 error?
High voltage power output error The measured voltage is not correct when the EGB measures each charge output (charge, development, image transfer belt unit, and transfer unit).
  • Disconnected or defective high voltage harness
  • Defective high voltage power supply
  • Defective EGB
  1. Check or replace the harnesses.
  2. Replace the high voltage power supply board
  3. Replace the EGB.
Jan 30, 2013 | Ricoh SPC242SF Colour Multifunction...
Lights 3,4 and 8 light up washer beeps
That is Error code 49,
49. (00110001) Phase 2 to 6 - Cold Valve Faulty (proportional)
The Motor Controller module has measured a voltage from the valve diagnostic
circuit that indicates the cold valve is faulty. The most likely cause is that the valve
harness has not been connected correctly or the valve is open circuit. See fault code 48 for service procedure.
48. (00110000) Phase 2 to 6 - Hot and Cold Valve Faulty
The Motor Controller module has measured voltages from the valve diagnostic
circuit that indicate both the hot and cold valves are faulty. The most likely cause is
that the valve harnesses have not been connected correctly or the valve is open
circuit.
Primary Source: Wiring.
Action:
Check the valve harnesses are correctly fastened to the valves or the pins are not
bent backwards.
Secondary Source: Water Valves.
Action:
Check the valve coils are not faulty (open circuit).
Tertiary Source: Motor Controller module.
Action:
Replace the Motor Controller module.
Nov 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykell mw5ll When turning power on wash cycle lights show up as well as spin light and just keep beeping will not allow any other changes to cycle
That is Error code 49.
circuit.
Action:
bent backwards.
Action:
Action:
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Why does my panasonic radio say F61 when i turn it on
Possibly a faulty audio power amp or power supply integrated circuit, a faulty fan perhaps.
A power source problem. Means there is probably voltage measured at the output/speaker connectors. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the ac power source from the wall is wired correctly and has proper voltage and grounding.
Apr 10, 2010 | Audio Players & Recorders
CMOS BATTERY DOES NOT GET CHARGE: DATE PROBLEM
It doesn't It is like a flash light battery.It is only on when the computer is turned off to keep the BIOS settings. Try replacing the battery,if date is not kept.
Mar 01, 2009 | Computers & Internet
RCA WSP150 Main / Stereo Speaker Logo
128 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
