Question about Troy Bilt Tb70ss Gas Trimmer
Replace pull cord on troy-bilt tb70ss - Troy Bilt Tb70ss Gas Trimmer
    President:
  • Troy Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25
Posted on Oct 03, 2010
  • 4 more comments
  • ianbhay May 11, 2011
    That Is Exactly what I did and the Pull Rope will not retract still even after rewinding of the spring coil. What do I do from here ?
  • Roy Cagle
    Roy Cagle May 11, 2011
    If the pull cord won't retract at all, either you wound the tension on the spring the wrong way or there is something binding in the starter recoil. If you didn't put it back together, do the rewind procedure again and before you complete it, make sure there is tension on the starter rope. Could anything you put back together be hindering the action of the rope as the starter pulley pulls it back in?
  • ianbhay May 12, 2011
    No there is nothing that is Blocking it and the tension spring only goes in 1 way. I will try it again and I will let you know incase I over looked a step or something along those lines
  • Rattweiler May 15, 2011
    I'm having the same problem. I believe my problem is with pre-loading the tension on the starter unit. Please explain HOW to preload the tension.
  • ianbhay May 18, 2011
    Yes please, Explain how to Preload the Tension so the cord can retract. I am just happy to see that I am not the only one having the same issue .
  • Roy Cagle
    Roy Cagle May 18, 2011
    OK...with the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are done.
Just a little FYI... do not put any type of rope in the piston area. Chances are the piston could move if it is not locked in place fully. This issue here with putting a rope in the piston area is that if the piston moves the rope will fray and could become lodged then you have material in the motor. And the problem I had was that the pull rope had broken off. So the solution is to put piston all the way and lodge it in place with a screwdriver. Then continue through with the instructions.
Posted on Jul 13, 2011
  • Roy Cagle
    Roy Cagle Sep 04, 2011
    It is really a personal choice isn't it. They make piston stops as well, but most users don't have them. Suit yourself. Rope material in the cylinder is a no-no, so your point is well taken, but many, many use rope to hold the piston in place.
  • Roy Cagle
    If the piston moves, the rope will only be compressed more, compressed rope does not ALWAYS equal fraying.
3 Suggested Answers
  • 246 Answers
SOURCE: TROY-BILT TB70SS - The pull cord broke and I need
Hello:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
>>Go to this Site Addy, http://www.jackssmallengines.net/parts.asp and Select Shop Online Parts Look Up. Then Select the Model Tab and Enter the OEM (Troy Bilt)and the Model Numbers. Now Double Click on your Model in the Results Area.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 279 Answers
SOURCE: cannot get the housing off so that I can change
If you are holding the unit where the drive cable goes in, there is a screw in there. It is a #15 or 20 TORX screwdriver. Take out the screw and it will allow you to get to the starting spool. Good luck...Lee
Posted on May 29, 2010
Replace pull cord
Replacing a pull cord is not easy. After you remove the shaft, then the drum cover, you are left with the drum and clutch. There is a screw in the center of the drum which has to come off. Then there is a the clutch which if not removed correctly will come apart on you. Only after both parts are remove can you get to the pull cord.
Oct 19, 2013 | Troy Bilt Tb70ss Gas Trimmer
Cannot get the housing off so that I can change the pull cord on my troy bilt tb70ss grass trimmer
May 29, 2010 | Troy Bilt Tb70ss Gas Trimmer
Spring assist starting not working
I would be looking at the starter pulley they are known to separate and jam the flywheel causing the symptom that you have, the only problem is you have to buy the starter assy to repair it.
Jul 27, 2009 | Troy Bilt Tb70ss Gas Trimmer
Pull cord
try this site it may help its called pats small engines
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy Bilt Tb70ss Gas Trimmer Logo
4,003 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
