Question about Samsung Syncmaster 17" 720N Monitor
Auto adjustment coming onscreen every 5 seconds, Help please!
  • 29 Answers
Hi the only solution that doesnt cost is........unplug....remove screws...take off front case......... where switches are there is a little white plug ........take it out of the socket.....put case back on...DONE power light and buttons dont work but monitor works fine 5min job no more menus hope that helped
Posted on Nov 28, 2011
How can I unfreeze auto adjustment screen on Samsung HDTV 24"
you ll need to go into the tv;s settings under display follow the onscreen instruction and turn the auto function off and set to custom should help
Apr 15, 2014 | Samsung Clothes Washer Drain Pump Assembly...
My jvc is showing black and white what do i do
Hello
Just reset the picture adjustments and se whether the colour comes up or not. If not, autotune it once more.
Reset resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
To RESET
Use [up-down-prog up-prog dn buttons] To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture adjustments.
Press the MENU button when finished
To autotune
?† To AUTO TUNER SETUP
Up or Down button To operate
To choose CABLE or AIR
Press the OK button to start
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen
Mar 21, 2011 | JVC HD-61Z575 61" Rear Projection...
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
My ps3 shuts down after 3seconds from booting up the light stays green and does not change color. i tried removing the hard drive and putting back in but still doesn't work. please help
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep).
and follow the onscreen instructions for resetting the ps3
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
Jul 10, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor fails to adjust-narrow in the middle
You have to use the OSD (onscreen display) to adjust the vertical height or the horizontal width.
If you have an auto button, try letting it readjust your monitor to the default setting. If this doesn't work, find the geometry setting and adjust the hoizontal or vertical manually to correct the "narrowness".
If this doesn't help, please reply with your monitor make and model number and we'll see if we can sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Computers & Internet
Auto adjustment comes on every 5 seconds
Sometimes that can be caused by a loose or bad video cable causing the monitor to re-adjust for the video signal. You could try resetting the monitor by unplugging it for a few hours and re-plugging it again too. Also check with HP and see if they have any warranty, extended warranty, repair notice, free repair/ replacement.
Jun 21, 2008 | HP f1905 19" Flat Panel LCD Monitor
Persistent menu on screen pop ups
I just had a similar problem, and it turned out that one of the little rubber buttons was pushed down and had gotten stuck under the plastic housing just enough to create contact, but hardly enough to notice at first glance.
May 05, 2007 | Zenith C27A24T 27" TV
Samsung Syncmaster 17" 720N Monitor Logo
90 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
