Question about Toshiba Satellite L505-S5966 Notebook
Error with HDD/SDD Alert. Removed old copy and installed original version. Same problem.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
Your ram may be faulty
Posted on Oct 02, 2010
Replacing hdd with new hdd with noway to recover my os win7 64 bit
Do you have the OS install CD? Hope you do... if not you may be out of luck unless you can borrow a copy from someone. To use your original OEM code it would have to be the exact version OS originally installed on the PC. Dont toss that bad drive yet though. After reinstalling the OS, add the bad drive as a slave and unless you beat it to death... you should be able to access most of the files on the old drive. Good Luck.
Apr 20, 2012 | Computers & Internet
I got a toshbia satellite laptop and when i turn it on it ask for the hdd/ssd password how do i fix this
You need to remember what the password is or take it to a Toshiba dealer who can fix it for you.
Feb 19, 2011 | Computers & Internet
Can I install a kingston sdd and install windows 7 to it?How do I get to the Hdd?Also what is the advantage of having windows7?
The HDD can be accessed/removed from the underside of the laptop. If you look at the bottom of the laptop, there is a rectangular panel in the corner (farthest away from the battery). Remove the screws holding the panel in place and lift up the panel. Underneath is the HDD. If you remove the wrong panel (the large odd shaped one), you will be looking at the two RAM modules.
You can certainly replace the old HDD on the Toshiba with an SSD. Windows 7 works very well with SSD's as you won't have to worry about installing drivers or any special garbage collection software, as these essential SSD features are already present in Windows 7. The most essential feature Windows 7 will offer for your Kingston SSD will be the TRIM command, this runs in the background and greatly improves the lifespan of your SSD (read more detailed info about this here).
Other advantages of Windows 7 is the improved security over previous versions of windows, and more importantly, no performance issues that plagued Windows Vista. Not to mention the thousands of applications available for Windows. There are of course, many visual features that are fun to play around with in Windows 7, but that's about as far as I will go to summarize the functionality.
Good luck and have fun, I installed a very similar Kingston 64gb SSD on my own laptop and I have yet to regret it (they are fast).
Jan 23, 2011 | Toshiba Satellite A105 Notebook
Please enter hdd1/ssd1 password....how to get start in normal mode
I presume that this message comes up when you first turn the laptop on. In that case the Hard Drive has been lock with a password. The is no way to remove this with either knowing the password or sending the laptop to a specialist who can remove the password for you.
Oct 17, 2010 | Toshiba Satellite L455S5980 Notebook
I am getting a "Toshiba HDD/SDD Alert, cannot access HDD" message. I looked under programs and found a Toshiba folder that allowed me to reinstall the alert device for the HHD monitor alert. It asked me...
Hi there lauren,
You need to REINSTALL the Toshiba HDD/SDD Alert Monitor. Try to look at the setup file under Program Files directory and inside the My Toshiba folder. It would be better to remove the program first thru the Add/Remove Programs in the Control Panel.
Should you need further assistance, please let me know.
Good Luck!
Jun 16, 2010 | Toshiba Satellite L505-S5966 Notebook
What is an HDD/SDD Alert? I have two error messages. One says "Unable to get disk info cannot use alert function. The other says "error has occured in Toshiba eco utility it will exit application. When I...
Under Programs in the My Toshiba folder there is a Toshiba Application Installer. Open(click) that and then re-install the HDD/SDD Alert Monitor. My Toshiba did the same thing and that's how I fixed it.
Dec 11, 2009 | Toshiba Satellite L505-S5966 Notebook
Samsung DVR HR 737 substitution Old original Hdd 160 GB (dead)
DVRs, not sure at the moment about the one you have, are limited with the brands and size hard drives it is able to accommodate. I'll advise you to check the manual you have with the DVR to see the brands and sizes that it can accommodate.
Sep 24, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
I keep getting the message 2010
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution There are three possible workarounds to eliminate the error:
  1. Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
    Note: This update requires a floppy disk drive.
  2. Replace the hard drive with one supported by the system being used.
  3. Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potential problems with diagnostic or copy tools. There are known issues with several of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided by Hitachi GST which uses vendor specific commands on the hard drive. These may not be correctly interpreted since they must pass through the serial to parallel ATA bridge. However, version 4.00 or later of the Disk Fitness Test (DFT) will work.
  2. HDDTEST version 0.28 by Hitachi GST does not function properly for similar reasons. Instead, use HDDTEST version 0.29 or later.
  3. DOS-based copy tools may function slowly or produce incorrect output, specifically previous versions of Norton/Symantec Ghost. These versions are not compatible with the Serial-ATA interface of the Intel ICH6M chip set. Documentation on this problem may be found at www.symantec.com. It is recommended to use either a newer version of Ghost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost 8.0 or later, or to use the -FNI switch when invoking Ghost from the command prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. The hard drives shipped in the affected systems will not display the message because they already have firmware that recognizes this new Serial ATA bridge chip. However, a similar drive from an earlier ThinkPad system or an OEM drive might cause the error message to be displayed. Customers may also notice the POST error message after applying a ThinkPad BIOS update if a drive without the firmware update is installed in the system. Some early systems were shipped with a system BIOS version that did not provide this POST error message. Updated BIOS has been released to provide this informative POST error message to users.
Apr 30, 2009 | Computers & Internet
Boot manager missing
The hard drive needs to be low level formatted, fdisk'd and FAT32 formatted prior to ME install. I don't know where to get free copies, but I've used both On Track's drive manager and Acronis v10. Bothe are very good your purposes. Both retail +- $50.00
Mar 23, 2009 | E-Machines eMachines Desktop PC
Cannot load fresh windows xp professional
I will agree, that uncertified OS often come back with refusals to install certain files as those files weren't copied correctly.
It's also possible that your OS disc is old and very scratched, which could cause information transfer issues. I suggest either using, or getting a DiscDr. if at all possible. They really do work, and it might save you from having to purchase another OS.
Mar 28, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite L505-S5966 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
