Question about HP Office Equipment & Supplies
Replacing ink jet - HP Office Equipment & Supplies
In the process oof refilling ink cartridge we experienced a leak in the cartridge, we drained it overnight and it ia now printing - but the printer keeps informing me that I am out of ink.
Posted on May 27, 2008
Epson Stylus C88 Ink Jet Printer only prints in blue but when i look at ink levels they all almost empty
Replace all ink cartridges and the printer will work again. The level indicators are just indicators and are not precise.
Jun 07, 2014 | Epson STYLUS C88 INK JET PRINTER...
My printer ink is full and it just printing in black and yellow
The ink leaves the ink-cartridge, and should flow through the ink-jets to be sprayed onto the paper.
If some of the ink-jets are clogged (blue, red) and some of the ink-jets are fine (black, yellow),
then you need to run a few "print-head-cleaning" cycles, to try to unclog those ink-jets.
Jul 19, 2011 | Office Equipment & Supplies
It ran out of ink, when I replaced the ink cartridge it will not print any more.
It is possible that your new ink cartridge is bad, but it is more likely that your jets on your printer are clogged - and that is preventing the ink from hitting the paper.
You can purchase an ink jet cleaning kit from your local office supply store and try that.
Also, if there is an available ink head replacement kit for your printer, it might be beneficial to go ahead and change that out now too.
Hope this helps!
Feb 23, 2011 | HP DeskJet 895cxi InkJet Printer
My printer is printing blank pages.
Either:
* empty ink cartridges
* clogged ink-jets, such that no ink can be sprayed onto the paper
Use the HP software to check the ink-levels in the cartridges.
Run a few "print-head-cleaning" cycles. If still no output, then replace the ink-cartridge(s).
Feb 22, 2011 | HP J4680 Office Jet All-In-One Printer
Black ink will not print text
maybe the ink jet cartridge is depleted. This is common on all ink jet printers.
Or, the ink jet cartridge has tape on the head.
Jul 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Hi. No magenta or cyan printing on my canon pixma 750. used the maintenance cleaning function and head refreshing to no avail. Any ideas,thanks Mark
Sounds like the ink jet cartridges need to be replaced. Cleaning will not solve the problem after the ink is depleted, and if the ink were low, the cleaning process uses up a lot of ink.
Good luck on replacing the ink jet cartridges.
Jul 16, 2010 | Canon PIXMA MP750 All-In-One InkJet...
C6380 - Ink System Failure 0xc19a0023 error message Just want to let everyone know i will never buy another hp printer again, i hve never had so much trouble with a printer, how can a printer only last 8...
as far as ink jets go i agree with you HP are pretty bad. However the HP color laser jets are second to none in my opinion. I work at a health care company and all we sell are HP laser jet printers. Sure the toner cost more money up front but page for page it's actually cheaper than having to buy all those ink jet refills. If you must have an ink jet printer I would try either a epson, cannon or lexmark. HERE is a good link to ink jet printer reviews
Apr 24, 2010 | HP Photosmart C6380 All-In-One InkJet...
Black lines running through certain lines of printed documents
Hi, ok your ink well is clogged (the stuff the ink cartridges fit in) remove all the ink tanks, then remove the inkwell by pulling the lever to the right. In a dish pour some rubbing alcohol and tel the ink jets soak a bit. pour some alcohol over the nossles(where the ink sits to send the ink through) and let it soak a bit more. Use a straw and cover the jets then blow, this will force the bad ink out clear the jets. Blot it dry then replace. blot each inktank before replacing them to insure the ink is running out. A couple of deep ink cleanings and you will be set.
If this fails you may have to replace the ink well and the cartridges (order new ones from canon) But cleaning it should work, try at least 3 times before deciding to buy a new one.
Dec 16, 2008 | Canon iP4500 Photo Printer
Nukote Black Ink Jet Replaces HP21
clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
Loading ink jets
Go here. Type "replace ink" in the Search window in the center of the screen and click on the Search button. Select "How do I replace or insert an ink tank?", then go to the section for installing the ink tanks.
Jun 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
16 people viewed this question
Ben Johnson
