Question about Suunto Pc Pod Wireless Transmitter
I have a suunto pc pod. my suunto t3d watch can connect to the pod but the pod cannot connect to the software installed (training manager lite) since my pc cannot find any drivers to install for the usb-device, (windows 7). I've read you can use Vista 64-bit drivers on windows 7 to solve the problem but i cannot find any drivers anywhere :/
    New Friend:
  • 4 Answers
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Posted on Dec 20, 2012
    New Friend:
I have a T4c, Suunto PC POD and W7 64bit and it work. Uninstall all suunto app and drivers including all suunto devices and drivers in windows device manager. Don\'t install driver from Windows Update. Install Movescount 1.0.39 from here http://movescount-prod.s3.amazonaws.com/downloads/Moveslink_setup_1_0_39.msi, newer version is garbage. it should work. If not try this driver SuuntoUSBSilabsVista.exe from here http://ns.suunto.com.edgesuite.net/software/drivers/SuuntoUSBSilabsVista.exe When everything working you can update driver using Windows Update. But it\'s not necessary.
Posted on Apr 05, 2014
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
I have Problem with the Suunto Pc Pod Wireless Transmitter Driver for Suunto USB PC pod with windows 7...
Good luck
Timco
Dec 13, 2010 | Suunto Pc Pod Wireless Transmitter
Driver for Suunto USB PC pod with windows 7 64-bit
I had a problem with the drivers for W7 32 bit, maybe it's the same problem:
Good luck
Timco
Aug 02, 2010 | Suunto Pc Pod Wireless Transmitter
Lost instruction to a digital/analogue pod watch
This watch appears to be made by "Suunto" and if you go to their web site, you should be able to find your watch detailed there.
If you then go to "support center", you will see "download center and user guides.
Jan 03, 2010 | Watches
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Have lost the software to install the 3com home connect
try this site my friend: http://www.howtodrivers.com/model565477.html
Step-by-step guide for install 3Com HomeConnect PC Digital WebCam Lite driver.
1. Download file for 3Com HomeConnect PC Digital WebCam Lite from our site, save it on your computer and unzip.
2. Connect your 3Com HomeConnect PC Digital WebCam Lite to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new 3Com HomeConnect PC Digital WebCam Lite on Webcams category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the 3comdriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new 3Com HomeConnect PC Digital WebCam Lite in Webcams inside device manager.
Hope this will help yoo fix your problem. If you need more assistance just reply to this post or contact me. Thanks
Jun 17, 2009 | 3Com Home Connect Lite Webcam
Downloading music into my ipod
first u have to install the i-tunes latest soft ware on teh pc and connect ur i-pod to teh pc with the dongle and the pc automatically decet ur i-pod and then the i-tunes soft ware will appear and in teh bottom teh page u can see auto fill click the tab and wait till the synk complete and u can use ur i-pod to listen songs thx rate me solved if its helps
Nov 15, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Suunto Pc Pod Wireless Transmitter Logo
995 people viewed this question
Top Suunto Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Suunto Cycling Expert? Answer questions, earn points and help others
