Question about General Electric PVM1870 Microwave Oven
How do you remove the vent door to replace the light?
  • General Master
  • 9,098 Answers
At our Web site, we have a video available showing how to remove the hood vent exhaust grille.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Oct 02, 2010
How do I remove the control panel
Main door lifts off. Look for screw under vent panel at top. Remove vent panel to find screw (s) holding control panel.
Oct 03, 2015 | Microwave Ovens
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
Sep 12, 2014 | GE Microwave Ovens
How do I replace the bulb in my GE JVM2070?
There are two screws holding the vent from the top, not front, that's why you don't see them. After you remowe them try to slide the vent to the left, it will move about 1/8" just enough to unlatch it and you can remove it. Your light bulb is hidden under a metal tin cover. Depress a small plastc latch in front of it and lift the cover...you light bulb is right there...good luck!
Rich
Nov 23, 2012 | GE JVM2070 Microwave Oven
There are stains in between the glass on the door. How can I remove and clean this?
Hello :
Disassembling the door yourself will void the warranty and may require a service technician to repair any damage or put the door back together. It is recommended that a service technician complete this for you. It is not recommended that you disassemble the door yourself.
Things You Will Need:
Glass cleaner
Soft cloths
Glass stovetop cleaner
Steps to Remove the Glass:
Make an appointment with a service technician to remove the glass from the door.
Use glass cleaner to remove as much of the debris as possible.
For tougher stains and food debris, use a glass stovetop cleaner to aid with removal.
Once the stains and debris are removed, allow the service technician to reassemble the door.
Cleaning Through the Door Vents:
When the glass cannot be removed or is no longer covered by the warranty, there are other, more creative, ways that can be used to clean it.
Long handled cleaner
Bottle brush
Yardstick/ruler wrapped in cloth
Bent hanger wrapped in cloth
Dryer vent brush
Glass cleaner
Soft cloths/towels/long socks
Duct tape (optional)
Steps to Clean Between the Glass:
Some Microwave ovens have small vents along the bottom or top of the door. These vents go in between the glass (and are likely part of the problem with other materials getting in there as well). By inserting a towel on a long-handled stick, you can gently clean between the glass without disassembling the door.First, find the vents on the door if you have them.
It may be easier to remove the door from the hinges and lay it flat on the floor. Many microwave oven doors simply lift right off of the hinges, others will require loosening a few screws first. Replacing the door should be easy to do at the end of the cleaning and will not void the warranty.
Start by choosing a long-handled cleaning tool. There are a variety of options available, so be creative.
Secure a towel or soft cloth (long socks work well) to the handle with duct tape or other strong tape. Make sure it’s well fastened so it doesn’t come off and become stuck in the door.
Moisten the towel or soft cloth with the window cleaner or other cleaning product.
Insert the cleaning tool through the vents.
Move the cloth back and forth to remove the debris from between the glass.
Remove the cloth.
Repeat with a clean cloth until all of the debris is gone.
Replace the door on the oven and enjoy the clear, clean view.
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
Need to replace interior light. Don't find any screws and can't get to top screws, if there. How is the light replaced?
you will need to remove the srews on the very top on the unit
they are above the vent
once those are out slide the vent to the rigfht and off
onve thats out in the center of the machine you will see the lamp acess door
it should just lift up but some manufacturesers put a srew in there you have to loosen to open it up
Nov 01, 2009 | Maytag MMV1153A Microwave Oven
LIGHT INSIDE OF OVEN NEEDS REPLACING --HOW DO I GET TO BULB
normally there is a side door that can be removed to replace the inside light bulb, the microwave bublb is changed from a different location normally on the back.
May 28, 2009 | Microwave Ovens
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
Charcoal Filter Replacement
Be sure the oven is disconnected from the wall first. Then open the door. Remove the two screws from the top of the grille. Next, slide the grille to the left to remove it. Before you slide the charcoal filter out, be sure to note how it rests at an angle on 2 side support tabs and in front of the right rear tab. After it's replaced, you can press OPTIONS until you come to the Charcoal Filter Reminder. Then you can press 0 to turn the reminder off, press 1 to set the reminder, or press 3 to turn the reminder on.
Jan 13, 2007 | GE JVM1860 Microwave Oven
General Electric PVM1870 Microwave Oven Logo
340 people viewed this question
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
Steve Mason
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
