Question about Dodge Car Audio & Video
2003 Ram Quad Cab - cd portion of audio system stopped working. Throws error for all discs. new, old, good, bad, it just won't recognize any discs. Problem started after battery was disconnected. Can't find any bad fuses. Radio functions properly.
  • 2,272 Answers
If the radio is functioning properly, but the cd portion is not detecting any cd disk then it can be cd lens problem. In the cd portion,where you insert the cd disk.Inside there is a lens,which reads the disk.If this lens is got dirty or if the lens is got weak,then it will not detect the cd and such problem comes up.The lens is a thin glass material thing.Its inside the cd disk player.The unit has to be disassembled to check the lens.But also before disassembling,you can try this.If you have a air blower then, in the area where you insert the disk,in that area just blow the air and see.If there is any dust got stuck up on the lens then it gets blowed,but if its faulty lens then this will not help.In that case the internal lens mechanism has to be checked and faulty components such as lens or lens moving motor or any short in internal wire has to be replaced. ------------- Check out.Keep updated.Thanks.
Posted on Oct 02, 2010
Heater only throws heat while driving at slow speed 04 ram 1500 hemi
pretty sure it doesnt have anything to do with subs unless the wired something wrong might have to take to shop to see if something wrong wid heater blower fan
Feb 23, 2013 | MTX Dodge Ram Quad Cab 2002-2003...
Fan for heater in 2002 dodge ram stopped working?
Check for a blowin fuse or a defective relay, If there good the blower motor is shot, End will need to be replaced,
Nov 28, 2012 | MTX Dodge Ram Quad Cab 2002-2003...
I have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
Jul 16, 2010 | MTX Dodge Ram Quad Cab 2002-2003...
2003 dodge ram 1500 quad cab radio take out
piece of fence wire bent in a U shape and push into the two holes either side of the radio fascia
Oct 24, 2009 | 2006 Dodge Ram 1500
Ford cd changer problems
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
Sep 07, 2009 | 2003 Ford F250 Super Duty Crew Cab
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
Car Audio & Video Logo
35 people viewed this question
Top Dodge Car Audio & Video Experts
xxxxxx xxx
Are you a Dodge Car Audio and Video Expert? Answer questions, earn points and help others
