How do i fix a paper jam on my printer? - Office Equipment & Supplies
  • 68 Answers
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Hope this helps. :)
Posted on Oct 02, 2010
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 36 Answers
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
hop this will help u ....
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 10406 Answers
SOURCE: major paper jam - all the paper has fed into the printer
Take the printer to a qualified technician, for proper repair, if you don't know "HOW" to properly disassemble/reassemble your printer.
Posted on Jan 14, 2010
  • 27 Answers
SOURCE: paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Posted on Jun 29, 2009
  • 13433 Answers
SOURCE: printer will not work after paper jam fixed
alternative :
Posted on Jul 09, 2009
  • 685 Answers
SOURCE: Paper jam
Here you go...
Posted on Dec 23, 2009
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Tip
How do I fix and avoid paper jam error issues in a Dell printer?
Fix and avoid paper jam error issues in a Dell printer-
Paper jam is one of the most common issues among all brands printers. Dell printers also show such issues and you will be indicated this error by the light or beep noise when a paper stuck inside. To avoid such issues on your Dell printer or fix the paper jam problem read here the useful tips that would be helpful to utilize Dell printing service with better efficiency.
Watch this video and fix paper jam issues in your dell printer: https://youtu.be/4nGBQ0H1RQw
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
I put paper on my hp printer and keeps jaming up wht can i do to fix tht problem thank you get to asap thanks again
60 Second printer paper jam fix by hp technician solves feed ...
? 4:56
www.youtube.com/watch?v=BdFvyDZmiFI
Oct 25, 2011 - Uploaded by BrokenPrinter1
60 Second paper jam fix by hp technician how to solve feed ...I've been trying to figure out why my printer has been jammingfor days! Days I ...
Fixing a Paper Jam - HP Deskjet 3050 All-in-One Printer ...
? 12:07
www.youtube.com/watch?v=suiQgoH-8cM
Jul 5, 2011 - Uploaded by HP Printer Support
My hp printer was working great until yesterday when I seemed to be taking ... I was able to fix the paper jam error on my friend'shp desktjet ink ..
Oct 20, 2015 | HP Office Equipment & Supplies
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
1,051 people viewed this question
k24674
jasbo
jasbo
