Question about Sharp Actius PC-RD10 PC Notebook
When i turn my coputer on it just beeps but if i hit f8 it will ask me what boot device i put hard drive and it starts it a sharp pc-rd10
  • 59 Answers
Start with the battery. Remove the battery plug in the charger and see if it boots up.
Posted on Oct 21, 2017
  • Sharp Master
  • 17,326 Answers
This sounds like the battery on the CMOS that keeps the configuration data intact has died.
Paeroa
  • 457 Answers
SOURCE: Need to Upgrade Hard Drive & Memory for Sharp PC-UM10M
SHARP PC-UM10 SPECIFICATIONS
CPU Ultra Low Voltage Mobile Intel® Pentium® III processor 600 MHz-M Memory 128 MB SDRAM, not expandable (model PC-UM10) 256 MB SDRAM (model PC-UM10M) Video ATI Rage Mobility M (including 4 MB video RAM) Display 12.1" XGA AGLR TFT LCD (1024 x 768) Hard Drive 20 GB Pointing Device Glide pad (touch-sensitive control pad with 2 buttons) PCMCIA 2.1 Card Slots Type II x 1, CardBus port supported Audio System Monaural microphone and monaural speaker, sound system compliant with AC 97 I/O Ports USB, LAN, modem, headphone, microphone, DC in, expansion port for port bar Modem 56Kbps (V.90) LAN 100Base-TX/10Base-T AC Adapter 100-240V, 50-60 Hz Battery Rechargeable lithium ion battery Battery Life Standard battery - approx. 3 hours. Optional extended life battery (CE-BL18) - approx. 9 hours. Battery life is based on ZD Battery Mark 4.01. Battery life may vary based on actual usage. Dimensions 11.1" x 9.1" x 0.65" (min)/0.77" (max), 282mm x 232mm x 16.6mm (min)/19.6mm (max) Weight 2.89 lbs., 1.31 Kg Operating System Microsoft® Windows® 2000 Operating Environment Temperature: 50°F to 95°F (10°C to 35°C) Humidity: 20% to 80% (non-condensation) Power Consumption Max. 40W Available Options Extended Life Battery CE-BL18 Optional longer life battery 6X CD-ROM Drive CE-CD05 External USB CD-ROM Floppy Drive CE-FD04 External USB Floppy Drive Port Bar CE-PB01 Provides additional I/O ports
Design and specifications are subject to change without prior notice. Some options may not be available in some regions.
[HOME] [NOTEBOOKS]
Posted on Oct 22, 2007
enda story
  • 61 Answers
SOURCE: hard drive boot
what do you mean by "it appears in device manager " if you cant boot there is no device manager. That aside it sounds like you are putting in to big of a drive for your BIOS so go to the motherboad,s web site and download the lastest BIOS
Posted on May 08, 2008
zohail
  • 1223 Answers
SOURCE: my desk top pc is steady beeping
if on power on u see nothing and just hear beeps and see blank screen with no text/signs of bios loading then my firend
ur RAM is faulty try replacing them and then tell me i can solve ur problem
hard disk comes after RAM if ur RAM is faulty ur system will never boot up and will give u beeps just disconnect the hard drive cable and check it ur selves if it boots to bios
pls ask for more help u want
regards
pls do rate me fix ya if i fixed ur problem
Posted on Mar 02, 2009
ssebata paul
  • 159 Answers
SOURCE: pc will not boot, windows logo flashes then blue screen flashes
check ram,hard disc if ok reinstall the operating system
Posted on Dec 30, 2009
  • 1481 Answers
SOURCE: will not boot to dos so i can format hard drive. i
get all info from my site on how to factory fit ur PC
www.sureshayyar.110mb.com
go to Support page
Posted on Jan 21, 2010
No bootable device, hit any key
The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
Sep 04, 2014 | Gateway Computers & Internet
Dell Precision M90 no boot and device status light next to power light is green
Here are Few steps which can use to trouble shoot your laptop no display problem.
1. Connect a VGA
cable for external monitor and check if you can see any display on External Monitor.
2.Take out your RAM and Clean it with Pencil Eraser and Put it back. If Possible try with different RAM,
3. Remove your Hard Drive and Try switching on Laptop without the Hard Drive.
4. Make sure that you are using proper Adapter with proper Voltage.
Aug 10, 2012 | Dell Precision M90 Notebook
Wants to install reboot disc
If you're looking to reinstall your operating system, you need to first turn on your computer and put the disc in the CD-ROM drive.
Then, turn your computer off. Turn it back on with the disc inside, and it should give you an option to "boot from disc" or something similar. Choose that option, and it will guide you through a step-by-step procedure to reinstall the operating system. This may take quite a while.
Mar 21, 2011 | Sharp Actius RD10 Notebook
Every time you turn it on it gives an error about the device in the modular bay, if you press escape to continue it says no boot devices, but if you reboot by pressing ctrl, alt + del it boots fine...
I need more info, can you get into the bios? Then there is a sellection bootoptions, sellect the hard drive put it as first bootdevice. You might have a empty bios battery so the bios can remember wich settings to use. I surgest replacing that battery anyway.
If its an older model laptop you can try hitting f8 f9 at the start, it will give you a bootmenu sellect the hard drive.
Still i need more info, wich type of pc or laptop!
Jan 21, 2018 | Dell Latitude 110L Notebook
My HP Pavillion does not boot up. there is a blank screen with blinking cursor. When I press F2 it asks for a driver disc that I do not have.
Is it saying booting from disk?
Try to turn off your computer for about 5 mins. Once you turn on the computer, you will hear it beep. Just after the beep, press f8 and select your hard drive so that you can boot from it.
Sep 16, 2010 | HP Computers & Internet
Had to f10 system. now im missing a file and cannot re-boot. what can i do
You might need to reinstall your operating system. Since it wont boot there isn't much you can do.
The first thing I would do is put your pc diagnostics disc that came with your coputer into the drive and run a system diagnostic. It will most likely find the lost file and replace it.
If that wont work then you have to put your windows operating system disc into the conputer and go to your boot menu by hitting f8, f12, or f2 (depending on your pc) then you select boot from disc. This will wipe all the files on your computer which means you will have to reinstall everything. This sucks but its a guranteed fix as long as the reason your system wont boot is broken hardware.
Jun 19, 2009 | ZT Group CISNET A7050 PC Desktop
My desk top pc is steady beeping
regards
Mar 02, 2009 | E-Machines T2042 PC Desktop
My Dell laptop will not boot up
Make sure that there is no cd inside the cd rom or floppy in the drive (if your laptop has a floppy drive),
Then go back to bios (F2), and choose your hard drive as priority boot option 1, save and exit.
As you computer boots up press F8 to get an option screen on how you want to start windows, select Last good known configuration. Hopefully this will boot your laptop.
Nov 20, 2008 | Computers & Internet
Hard drive boot
if you can't see the hd in bios, it's not really there..right? you can turn it off, in set up, restart, then enter setup again, and turn it on..make sure it's seated firmly in that section, yes?
May 08, 2008 | Computers & Internet
Sharp Actius PC-RD10 PC Notebook Logo
83 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
