Question about GE Profile JVB67 36" Telescopic Downdraft Ventilation System: Bisque on Bisque Kitchen Hood
I have a little trouble :) with my downdraft model jvb66 it dont up or down anymore just make a noise. What can I do?
5 I have a Bradford White gas water heater. Model number MI 403 23626 number 1 3 1 - 7 7. I have replace the thermocouple because the pilot light will not stay lit. It will heat up for a little while, then...
Check pilot flame is it good, is the thermocouple in the flame, is the flue causing a down draft, or to much updraft, Is the ceiling in your closet close to flue to keep a downdraft out. Last replace gas valve.
May 28, 2018 | Water Water Heaters
Hi Guys, you must be getting this a lot, but i am going nuts! I have a Hitachi 5K320 250Gb Harddrive that for some reason I cant get in anymore. I have very important stuff on there that i need for my...
I know it sounds a little nuts but try it with the drive upside down or on either side or on end supported by some books, you can also try cooling it off in a fridge for a while. when a drive starts to go and starts making clicks and vibe noises you have very little time to get everything off. before you try anything make sure you have space to save the files if you do get in.
Also look into Puppy Linux it runs in ram without running the hard drive,
Puppy may be able to read your drive.
I'll check in with you later, off to work.
Regards
TickMagnet
Aug 16, 2011 | Hitachi Travelstar 5K320 320 GB SATA Hard...
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Change blower to down draft
I dont think you can change a gas furnace from horz/upflow to downdraft,the inducer motor would never prove the pressure switch, the drainpan would upside down,you can order a downdraft unit, i dont believe this unit is made for that
Sep 30, 2009 | Goodman GMS90703BXA Heater
GE Profile Telescoping Downdraft system gets stuck.
try to remove your cooktop and see if the vent unit is in your countertop too tightly. by removing the cooktop it will give the vent more space. if it works that way, then you might have to make more space for both to fit properly. i have seen this happen before and its probably what is causing it to bind and then drop suddenly. i hope you dont have a marble, slate or rock type countertop as they are very hard to trim just a little off to get everything to fit.
Jan 07, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
Kitchen Hood
Hi absimp,
I'm Harvey the Master Plumber.
Your question is: You are having trouble cleaning your downdraft hood...you are able to remove filters and clean but there seems to be grease build on the hood as well....The smell is really bad but you can't get down in the hood to clean. Is there anyway to remove the hood in order to clean it better??
The short answer is; not really. But don't be dicouraged yet, you shouldn't have to . There is a brush on a long handle that looks like the kind of brush you would use to wash a glass. I wrap the brush part with a small cloth that is wet with cleaner and just use from above rinsing the cloth as nessessary. If you have trouble finding a brush long enough just go to a plumbing supply and buy a brush made for cleaning the soot out of a boiler. If they know your problem they weill be happy to help.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 26, 2008 | Frigidaire HV2736B Kitchen Hood
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
How to replace up/down switch in downdraft vent for cooktop
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Jul 27, 2007 | GE Profile JVB67H Kitchen Hood
Kitchen Ranges Logo
131 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
