Question about Canon PIXMA iP4600 Color InkJet Photo Printer
I have a canon ip4600 printer flashing the amber light 10 times ...what does that mean ?
  • 193 Answers
SOURCE: my canon ip5200 flashes 13 times amber
UR ink pad needs to be replaced
Posted on Mar 18, 2009
SOURCE: I need a tool to reset my canon pixma iP4600 ink cartridges
I found the only tool I have seen at this url. http://www.patronenhandel.de/shop/index.php/cat/c13943_Canon-Chipresetter.html It is a German company, but I was able to order the resetter from them with no problems. It has worked very well, but was a little expensive. part of the problem was that the US dollar and Euro were not at a favorable exchange rate when I ordered. I didn't get any answers to my emails to them, but when I used there site to order, it took about a week to get the device. It is very simple to use.
Posted on Jun 14, 2009
komguy
  • 2306 Answers
SOURCE: what does error 6000 mean on a canon ip4600
Error 6000 is a line feed error, it means the platen roller isn't advancing properly. It usually means something has fallen in from the back where the paper goes and is stopping the rollers from turning
Posted on Sep 08, 2009
e-ware
  • 776 Answers
SOURCE: Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Sep 13, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
Canon MP-5200 printer will not turn on display
6C10 means you need to replace the ink absorber. After this it require to reset the error. Reset 6C10
Oct 15, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
My Canon PIXMA iP4600 keeps reporting a B200 error. Turning it on and off has not helped yet. What else can I try?
I am sorry to say that you will need a new printhead and main logic board to solve this error. What has probably happened is the printhead has shorted the logic board. So unfortunately you MUST replace both together. I think this may be rather expensive.
Sorry.
Jun 19, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Hi there i have a problem with the Canon iP4300.
may be the printerisnt seeing the cartridge ,or its empty,.or the jets are blocked
Jun 27, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Have a new canon pixmaiP4600. Installed software
open the cartridges may be stuck off and installed
first is printer is good ofter prin out coming
Jun 10, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Canon PIXMA iP4600 - error 6A80
Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
Jun 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
492 people viewed this question
old marine
old marine
