Question about Kirby G4 Bagged Upright Vacuum
Belt replacement Putting the belt bagk on
  • zuzi5 Jun 16, 2008
    I have the problem of getting the hook to engage the belt. The hook only grabs the belt when it goes in the opposite direction and the red arrows line up. This is wrong because you cannot close the lid (that holds the light) The solution given here does not tell me how to remedy the problem. More specifics, please!
  • Anonymous Jan 04, 2009
    same problem
  • 357 Answers
Please check out my step by step instructions.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Posted on Jun 22, 2008
    President:
  • 1,673 Answers
Put the new belt over the brush roll, install the brush roll back into the nozzle with the belt in the center, put the bottom plate on then turn the big knob on the from until it locks(it will catch the belt)put the nozzle back on the vac, lock it down, and turn the knob to release the belt unto the motor pulley.
Posted on Jun 01, 2008
How to replace belt on hoover SH40060
You have to remove the roller to get to the belt' look at the face and bottom to find the screws that hold the plate that covers the roller. Take the plate off and look @ the roller, to see where the belt runs. then take the roller out, you should be able to see the pin shaft that comes from the motor,the belt goes around it and over the roller.Be patient putting it all back together,and don't over tighten the screws, they strip easily, Good luck!
Feb 20, 2015 | Hoover Vacuums
Howto change a belt
Remove the top or bottom cover of the power nozzle/base of the vacuum. The screws will be on either the top or bottom of the base. Remove these screws to gain access to the brushroll. Remove the brushroll and attach your belt then putting the belt around the brushroll and using the brushroll to stretch the belt into place. Replace the top and bottom cover.
Jan 10, 2012 | Vacuums
Can't replace belt roller want turn after putting belt on
First make sure the belt is centered properly. If it's not, the belt will break before you've even used it. Depending on the model of vacuum, there should be a reset switch on the power head, or back of the machine.
Dec 20, 2010 | Eureka Vacuums
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
Motor noise and burning smell
your belt is of the guide arm try replacing the belt usually located @ the head of the vacum there should be 4-6 screws holding the head on remove it in well ventilated area try putting on mask cause you will release all the dust from the head when you take it apart you will see the belt around the brush remove the brush and bearings togther then replace belt if you know your model # of your vacum u can usually find replacement parts online or @ most sears and walmart outlets.
Jan 26, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Charlie
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I put a new belt on Hoover Concept One vaccume cleaner?
you most likely have to remove the cover over the roller, which has screws usually. then you will see the belt. the roller slips out replace the belt by putting it over the roller and a metal rod that is up under the cover you removed. this will be a hard job putting the roller bar back in the vacuum because the belt is so tight.
May 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing belt
If you flip the machine over with the beater bar looking upwards. Locate the three/two screw heads and undo with a coin. When the roller section is revealed by taking off the floor head you should replace the belt with a new one and be careful putting the beater bar in the right way on both ends. The belt will be tight brand new so expect some tension in it.
Mar 02, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
Kirby G4 Bagged Upright Vacuum Logo
272 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
