Tone arm consistently retracts as if the record was finished
  • 4,234 Answers
Without the make and model, I can't give you much at the moment, but if the unit is an older one, the problem is that the grease has gotten stiff and won't let the mechanism work properly. Please update this with the make and model and more specifics will be provided.
Thanks,
Dan
Posted on Oct 03, 2010
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
On a L-A55, what causes the arm to retract not high enough and cause the needle to scratch across the record?
I think you you mean the lift and there is are screw on it , and a feather on the other side, turn the screw to the the right a bit , so it gets a little lower
Oct 16, 2014 | Audio Players & Recorders
Record doesnot finish and tone arm does not retract
Are you sure that the deck has an auto retract function? Give make and model please
Aug 31, 2014 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
Cr79 tone arm stops too early
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
/uploads/images/cr79-tone-arm-stops-early-34896944-4-1.jpg
May 09, 2010 | Crosley 0187SST Turntable
Tone arm retracts before recording is complete (CR-245)
actual old units (not sure about modern nostalgics) sometimes had a lever that said 7 or 12 inches for 45's or 33's this would tell the mechanism when to set down the arm. If your unit does not have something like this then it sounds like an internal failure that would require it being opened by a tech or sent in for warranty repair.
Feb 10, 2009 | Crosley CR249TA Turntable
Record won't retract
If it isn't making any move to retract the tray it's probably the trip switch. If you look in the back and follow the mechanics under the tone arm you'll see how it closes a switch as the arm goes to the centre of the record. Clean the switch or adjust it.
If it is half returning the tray it is the tray stack all gummed up. Use Servisol Silicon spray or have it rebuilt by someone who knows how.
Dec 06, 2007 | Wurlitzer Jukebox 1015 One More Time...
 Grubhead
Grubhead
