Question about Kenmore Elite HE4 Electric Dryer
Dryer problem when turn power on to dryer all control buts light up that are suppose to then i pick a setting such as bedding and push start but the dryer doesn't start.
    President:
  • 2,712 Answers
Is it that the dryer does not start at all, or there is no heat?
Posted on May 26, 2008
  • Swilin Sampson
    Swilin Sampson May 26, 2008
    First thing to do is verify your source voltage for the dryer make sure you
    have 240v. The dryer motor only needs 120v supplied by one of the lines to run.
    But the heating elements, on the other hand, need 240v supplied by both
    lines to get hot.
    If the source voltage is ok, then the most likely bad parts are listed
    below.
    1. Even Heat Board
    2. Heater Relay
    3. Thermostat
    4. Sensor
    I would recommend that you get a repair guy to check these out if you have no previous experience dissembling the dryer.
    Hope that helps! Should you have any further questions,
    please post them here.
    If you are satisfied with my solution or have no further queries, please take a
    moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
Nothing happens when you push the start button. If it is set on moisture control the indicator light goes on. we tried to find the relay switch but could not find it. we checked the thermal switches...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Dryers
When I push the start button the dryer will not start. All of the lights light up like it is supposed to ,including the one that says "Flow Sensing", the dryer will set for a few minutes without...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 24, 2011 | Samsung DV419AE Dryer
Dry does not turn on. there is power. lights on can dial to the setting but when control pushed to start it just hums.
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 17, 2010 | Maytag Dryers
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer starts after setting time without pushing start button
The control switch assembly needs to be replaced. The start button is sticky.
Sep 01, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
