Question about Maytag Legacy Series Top Load Washer
Will not spin - Maytag Legacy Series Top Load Washer
    Genius:
  • 1,416 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Posted on Oct 02, 2010
    The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
    Reasons Why Your Washing Machine Won't Spin
    losangeleswasherdryerrepairservice.com > News
    Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
    Spin Cycle Not Working on Washer ' ThriftyFun
    www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
    My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
    How to fix a washer that will NOT spin ONLY. THE EASY ...
    ? 3:56
    https://www.youtube.com/watch?v=_8myOfPzGfM
    Aug 4, 2012 - Uploaded by Brad Hyman
    My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
    Feb 09, 2016 | GE Dryers
    I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
    check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
    it it is not slapping in when it goes to spin , it will not spin
    Dec 18, 2015 | Samsung Washing Machines
    AWO/D 4505 not spinning
    does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
    May 15, 2014 | Whirlpool Washing Machines
    Will not spin on spin cycle
    Brian...You have a Non-compliant washer! Brian...You need to replace and Install a New Drain Pump! She will Spin, Spin, Spin all day long afterwards~
    Jan 20, 2014 | Whirlpool Washing Machines
    Not spinning on spin cycle
    No spin is electrical!
    Nov 28, 2012 | Washing Machines
    Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
    1) may be your spinning cloth load over.
    2) Check inside the container (space of wall & spin tube) cloth may be inside.
    3) Door stopper (Brake) position not correct.
    Actually the spin motor starting slowly first.
    Mar 26, 2011 | Washing Machines
    Printed wash cycle info missing from front of machine
    Quick wash cycle for the Hotpoint FEW12 is 'K'
    A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
    B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
    C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
    D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
    E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
    F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
    G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
    H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
    H...(Wool mixtures with cotton or rayon.....2.5 kg)
    J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
    K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
    L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
    M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
    N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
    P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
    Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
    Hope this helps
    Sue
    Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
    Washing Machines Logo
    70 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
