Question about Motorola Mobility HS850 Consumer Headset
Can I pair my motorola 05327n blue tooth head set with more than one phone and how do I do it if I can or how do I switch to the new device
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
My LG Shine phone will not pair up with my new Motorola Bluetooth device. (T505) I've tried everything!!
Motorola blue-tooth devices are mostly meant for Motorola phones. This particular device is restricted to be used by Motorola phones. No matter how hard you try the devices will not pair because they are not compatible.
There are certain blue-tooth devices which are universally acceptable by all types of mobile phones but the MotoRokr T505 as it is dubbed by Motorola is restricted to Motorola phones.
Sorry for any inconveniences.
Please do rate the service delivery on this question answered.
Jan 03, 2011 | Motorola Mobility MOTOROKR T505
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
Have a nice day.
Sep 01, 2010 | Cell Phones
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
''device not found'' on motorola I465 when attempting
you have to turn on the discovery mode on the phone in the blue tooth settings....usually will last for like a minute or so then hit the search or pairing button on the head set.
Oct 02, 2009 | Motorola Cell Phones
The phone with which my H350 Motorola wireless head set was paired , got lost. How to pair the head set with my new HTC phone
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Nov 27, 2008 | Motorola Mobility H350 Wireless Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
Blue Tooth Pairing
I think that you are usiing an uncompatable headset or your doing it wrong.
How to pair your Bluetooth Head Set:
  1. Turn your Bluetooth on, on your phone.
  2. Turn your Head-set on.
  3. On your phone, in the bluetooth menu; go to "Look for Devices".
  4. Your phone should automatically detect the headset and allow you to connect.
Try http://carphonewarehouse.com to see if your bluetooth head set is compatable.
Jan 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility HS850 Consumer Headset Logo
227 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
