I have a Samsung LNT 4066FX/XAA LCD 40in flat screen approx 3 years old. Over several months it progressively took longer and longer to come on. Then when it did come on you only got the color lines on the screen with sound after turning it off for a few seconds and then turning it back on it would come on after a couple of minutes with picture. Now it will not come on at all and when you try to turn it off it continues to attempt to warm up.....Is it worth fixing....... please help....Thanks
  • 3 Answers
SOURCE: Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Posted on Feb 20, 2009
  • 22 Answers
SOURCE: samsung lnt4065fx/xaa with 100's of colored lines
Sound like one of two things: A test screen, or a broken TV. More likely than not, your television is broken. Try hitting TV/Video on your remote, and if that doesn't work, power the TV off, unplug it, and plug it back in. If none of the works, it's time to call a repair man.
Posted on Oct 29, 2009
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Posted on Mar 29, 2010
  • 11800 Answers
SOURCE: I have a 40in polaroid flat screen and I can't
The cause depends on how you use the tv and what are its connections.
If you are using a box of any kind then the defect is in the the connection: either the cable connecting the tv to the box is damaged and it will have to be replaced or the selected input in the tv's menu isn't the one actually used - this happens when you use a Composite or S-video connection and you have selected as input the Component or the RGB connection. In that case just select the correct one. Of course i've assumed that you have correctly plugged the cable.
If you are using the tv directly from an antenna or the cable then the problem is in the tv system used: it should be NTSC or automatic and it's set on PAL. Depending on the exact model of your tv this setting can be found in either the Setup section (usually under the Country or System options) or in the Video. To fix it you will need to go into the Menu, find it and set it correctly.
Posted on Jul 15, 2011
Samsung model ln52a750r1fxza start to power up chimes and then clicks off then repeats itself - unpluged and pluged back in just repeats without me doing a thing.
Had a similar issue with my set LNT 4061FX/XAA. After doing some research on line I found that Samsung company had an issue with some capacitors. There is a group action law suit. I found that my set was included. Called Samsung and they were extremely nice and helpful. They called a local repair shop, gave them a invoice charge #, and the repair shop ordered parts needed for me. I took TV to them (althought I was offered home repair), and my TV was fixed for "FREE"!!! Got it back and working better than it had in years!!!!! Thank you Samsung!!!!
Jan 20, 2013 | Samsung LN52a750R1FXZA
I have a Samsung LNT-4042HX-XAA where the far left side of the screen is scrambled when viewed in 16:9 and is visible in other ratios. The main board was replaced not too long ago for a hefty price. I...
Can you please upload an image to imageshack.us so that I can see for myself what it looks like? That sounds like t-con or LCD panel issue to me.
Oct 24, 2010 | Samsung Televison & Video
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Turns off and sometimes comes back on by itself
DLP --- need to exchange the thermostat.
LCD --- replace the Main Board.
PDP --- need to check Power Board or Y-Main
Jan 29, 2009 | Samsung Televison & Video
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
