Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool noise There doesn appear to be anything in the wash tub, I also spun it manually and didnt hear any scrapping, when it spins there isnt a burning smell either, it kind of sounds like its coming from the motor.
    Novelist:
  • 177 Answers
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
Posted on May 28, 2008
Plastic shaving in wash from ring around basket. What could it be. Model GHW9400PW0 Whirlpool Duet
k where they came off from so you can put them back otherwise it will leak. Inspect the inside of the unit while the tub is out (bearings, etc) to make sure there isnt anything else. Hope this helps!
Jan 30, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Just finished washing a load and putting in dryer when I noticed the clothes were still wet. The tub was drained just not spun very well. So, I set the dial to spin and heard a motor noise but no...
hello, it sounds like to me that your clutch is going out on u and mos tlikely did . this means u may or will have to replace the motor or just pick up a used one or new one .
hope that helps.
good luck.
thanks.
veronica gillespie
May 06, 2011 | Washing Machines
Hi I have a Whirlpool 6th Sense Washing Machine - AWM8143. I is washing and spinning perfectly well and there are no error codes. However when it spins the machine makes a grating squeaking noise that is...
hi,
looks like there is some friction between the main and outer tub of your machine. there is generally a mechanism for smooth spinning of the machine in good rpms for wash-spin cycle. this could be because of rust formation, or mud collection. please refer your manual and remove the 3 screws behind the lower front plastic cover, and look for rust formation. scrape the rust and try spinning again.
cheers
Jul 26, 2009 | Washing Machines
OFF BALANCE WHILE SPINNING
spin the drum with hand to hear any noise from the bearings on the back of the drum, the drum should turn freely with no grating noise.
May 12, 2009 | Washing Machines
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
