Question about Danby DPAC120068 Air Conditioner
My Danby air conditioner is getting error E03 and the blue light is flashing. It appears to be working fine other than that. Can you please tell me what this error means and how to fix it. Do you think it might help to unplug and reset the unit?
  • 95 Answers
SOURCE: Unit switching off
Take it back, if it is new it will be under warranty.
Posted on Jun 10, 2008
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
koolbreezes
  • 540 Answers
SOURCE: Danby Air conditioner
Check out the co. website, for that unit and codes for troubling shootings! Thank-you-very-much!
Posted on Aug 27, 2008
  • 1253 Answers
SOURCE: danby portable air conditioner
https://www.danby.com/registration.php?ln=USE&
Go to this web site to register your product.
Posted on May 20, 2009
  • 54 Answers
SOURCE: Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Posted on Jul 02, 2009
I have a Danby Premiere mobile ac unit and it has been working just fine, as of yesterday it all of a sudden just quit working. I can plug it in and it will run for a few seconds and then quit. once i
Hi There,
I would like to help you with this but I need some more information.
Is the display showing any error codes?
Is there a red light blinking?
From what I have learned from a technician, with the weather being so hot and humid in most areas it is likely that the water bucket is full.
If this is not the case, please either respond to the questions above and I will look into this further or you can contact our Customer Service department at 1-800-26 Danby for assistance.
Thanks!
Jul 18, 2012 | Danby Premiere Series DPAC12010H 12,000...
The blue light keeps blinking and error e04 comes up
I have a DPAC 1200068 air conditioner and the red light keeps blinking and I need to know how to shut it off so it flashes when it is suppose to and go off when it is suppose to.
Jun 21, 2010 | Danby Portable Air Conditioner
Danby dpac120068 blue light flashing with error code E04 and the compressor keeps turning off randomly. What is causing this? What does E04 mean?
E04 refers to Overheating. There might be plenty of reasons. You might have seen, if you shut down the ac for few minutes and again start it, It would work for few minutes and the same E04 display is there.
This is tech's job. I am sorry, i am not discouraging you but it requires certain testing that actually what makes ac overheated.
This is dangerous. So, better to call a tech and get it checked!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | Danby DPAC120068 Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Have a E1 error on our Danby Air Conditioner
E1 error on Danby is to clean or replace air filter. Check that filter is properly installed as that may also cause the error.
Jul 31, 2008 | Danby DPAC8020 Air Conditioner
Red flashing light
Had the same problem, thing shutting off after an hour, no water in the tank. I had the external tank attached, was always bone dry. What I didn't know was on the side, there is a slide out tray which acts as the internal tank. The lid to that tank activates a micro-switch which tells the unit that it's full. This tank was dry too, but the switch was getting jostled, casuing it to trip. I've taped down the switch now, and it's fine. I check the tank every few days, just to be safe, but it's never got any water in it. Hope this helps.
Jun 25, 2008 | Danby DPAC9030 Air Conditioner
Unit switching off
Jun 08, 2008 | Danby Portable Air Conditioner
Danby DPAC120068 Air Conditioner Logo
147 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
