Question about Onkyo TX-SR502 Receiver
'phones engaged' no sound
Onkyo 805
purchased from US shipped to uk. bought step down transformer and connected.
everything connected properly but no sound
display shows earphone symbol. hence all channels no sound.
anyway to by pass.. is this an earphone socket problem or could the transformer cause the proble.
system power 870w.. transformer covers output upto 1000w
thanks
Well,
My onkyo receiver was keep displaying "Phones Engaged" and no sound.
All I did was plugged in a phones plug and remove it and for the last 2 weeks there is no problem.
I just happened to have a phone plug (without the actual headphone or wires) and that seems to fix the problem.
Hope it will work you all of you as well.
Good luck.
Posted on Jul 30, 2009
    Novelist:
    Champion:
  • 218 Answers
What is the mains voltage in the UK? In the US it is 120volt at 60 cycle. Is the UK using 60 cycle as well? If you are using 240 volt then you will want to hook it up so that you have a step up in voltage and not a step down. Are you sure that you cannot change a switch or jumper on your unit in order to switch to your "mains" voltage and not use the transformer at all? If this is a brand new unit and you are having this problem then I would suspect that it is a transformer problem.
Posted on May 27, 2008
I have bought an ONKYO HTS-6300 from the USA (120V) and tried using it in India (220V) using a step down voltage converter. The receiver shows the red light but unit does not get on. It keeps on making a...
Hello
You have to use a step down transformer with this set and not a converter. The AC household voltage in Inda is 220VAC. Your set is designed to work on 120VAC. Therefore a 220VAC==>120VAC step-down transformer is needed to feed it. The onkyo has transformer inside, and it should get 120VAC; atleast 5AMPS current capacity. AN inverter cannot synchronised with this set. You can either buy it from Inidan electronics spare part market, of can be winded by expereiced transformer winders. Never give any inverter to this set, as some Onkyo models will have Torroid transformer inside, and it will take a tremendous amount of current at start-up, and make either your Onkyo of your converter to get damaged. OK.
Jun 13, 2011 | Onkyo HT-S6300 Theater System
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
Onkyo CR-325
According to the manual, the sleep timer can be set to shut the unit off after a specific time. The other timers can only be used to trigger the amp to play or recored at specific times, and only if the recieiver is left in standby, otherwise the timers are ignored. There should be no reason the sleep timer does not work if you are following the procedure outlined in the manual (http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/CR-325-_E)
Sounds like the transformer or something went in the other amp. Not related to the timer issue. Both amps having the smae timer issue suggests that it is a programming issue (follow the procedure in the manual step by step), if you still cant get it to work, get it covered under warranty while you can.\
Hope this Helps
Jer
Jan 15, 2010 | Audio Players & Recorders
HEADPHONE ENGAGED AND NOT PLUGED IN.
When your son pulled out the headphones he must have broke the auto pressure switch right inside of the headphone jack input (its most lickly just bent out of place making a contact that is telling the amp the headphones are still in! you can try to bend the contact back into place...but if it is broken it will need replaced (a cheap repair!)
Please rate my response and help keep this site free!
Jan 03, 2009 | Onkyo HTR500 Receiver
ONKYO TX-SR805 Display screen does not light up.
Resetting the unit MAY work, however you will reset everything to factory and have to set it all up again. If resetting does not work, sounds like you will be looking for your local, friendly rrepair shop. Onkyo carries a two year warranty on these units, hopefully yours is still under. If not I would contact ONKYO directly because it seems they have had A LOT of problems with the screen on the 805 and 875 models
Sep 30, 2008 | Audio Players & Recorders
I have a Onkyo 805 Receiver that while I was listening to DVD Video in DTS Mode the sound stopped and the TV went to input. I noticed the Display on the Receiver said E2PROM ERROR. Now I can't get anything...
WILL TRY TO GET A SOLUTION FOR YOU IN MORNING CALL ME ON 02870342354 LARRY. I HAVE NOT SEEN THIS ERROR BEFOR AND I SELL ONKYO IN THE SHOP I WORK IN,(LIGHTING,SOUND,AND VISION) IN NORTHERN IRELAND OR EMAIL ME AT LSVNI@YAHOO.CO.UK
RICKY.
Jun 19, 2008 | Onkyo Audio Players & Recorders
I need help also... I'm having the same problem straight out of the box. I guess no solutions have been found here yet? :(
Jeremy
JeremyBW@gmail.com
May 17, 2008 | Onkyo TX-SR800 Receiver
Usa to uk
Hi mick
the unit has a voltage selector switch on the rear. Have you selected the 220v option. this will solve your need for a reduction transformer. If you have just gone ahead and fired it up in 110volt settings.... internal damage may have already occurred.
What is the switch set to now? Let me know
regards
Graeme
Feb 17, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR502 Receiver Logo
557 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
