Question about Concept CC-2502 Car Audio Amplifier
I need a owners manual for a concept cc- 2502 amplifier. cana you point me in the right direction? Gil
4 Suggested Answers
thesoundman
  • 41 Answers
SOURCE: Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Posted on Sep 21, 2007
etirbynnor
  • 655 Answers
SOURCE: what speakers
Hello enot99,
The CC-2502 is a bridgeable 2-channel amp. If you want to drive normal speakers in stereo, the best would be a good set of components with separate woofers, tweeters, and crossovers. They are available in many sizes from most car audio manufacturers. I'd begin by finding out what speakers fit the location where you intend to mount them. Then I'd browse the speaker selections in that size at www.crutchfield.com. You can also use the "outfit my car" feature to browse only the products that fit. Then select a pair that has a power range and impedance to match the amp: 250 watts RMS at 4ohms or 450 watts RMS at 2ohms.
If you want to use the amp in bridged mono mode to drive a subwoofer, again Crutchfield has a large selection of subs and some enclosures already fitted with subs (loaded). The amp claims 850 watts RMS into 4ohms bridged, so look for a sub that has a power handling rating of at least 850 watts and it needs to be 4ohms.
Hope this helps.
Posted on Aug 02, 2009
97F350diesel
  • 1326 Answers
SOURCE: i need a rebuild kit for the concept cc-2502
lol, there is no rebuild kit for an amplifier. You will need to go to radio shack or an electronics store to get the replacement parts. Try this site
http://www.mcmelectronics.com/
Posted on Sep 14, 2009
How much rms dose amp have?
Concept CC-2502 2002 900 watts max Rms
Feb 24, 2011 | Concept CC-2502 Car Audio Amplifier
I dont know how many watts it is
4 Ohm Stereo Power (RMS): 250W X 2
4 Ohm Mono Power (RMS): 850W X 1
2 Ohm Stereo Power (RMS): 450W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 16.93"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
How to install cc602
How do you hook up Concept amp CC-452.
Oct 31, 2010 | Concept CC-452 Car Audio Amplifier
I need a rebuild kit for the concept cc-2502
Sep 12, 2009 | Concept CC-2502 Car Audio Amplifier
What speakers
Hello enot99,
Hope this helps.
Aug 02, 2009 | Concept CC-2502 Car Audio Amplifier
Bridging CC-452 or CC-752 amps.
either will work fine, as long as it's a + from one channel and a - from the other.
Jul 20, 2009 | Concept CC-452 Car Audio Amplifier
I need to know how to wire a single 2 ohm sub to a concept cc-d800 to make amp run 2ohm
If your sub is 2ohm it's just left positive and right negative at the amp to the speaker. Hope this helps
Jun 26, 2009 | Car Audio & Video
I have a 2400 watt concept amplifier and if i turn it up too much it sends a real loud hum throught my subs. I really want to get it fixed because this has ben a very good am to me. If i need this repaired...
yes that cause from yhe gain is too high on the amp and you getting a ground loop traveling thru the rca signal
once the gain is high you will hear it make adjust on amp
Mar 29, 2009 | Concept CC-2502 Car Audio Amplifier
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
Concept CC-2502 Car Audio Amplifier Logo
83 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
