Question about Toro Lawn Mower With Toro Power Tools
My lawn mower starts fine after i prime it but then shuts off aer 10 seconds
    Problem Solver:
  • 5 Answers
Sounds like it's starved for fuel. Usually this can be fixed by cleaning the carburetor and/or installing a carb kit. What are the model and type numbers stamped on the engine?
Posted on Oct 03, 2010
Garden tractor
sounds like your choke is not shutting all the way. Throttle pushed all the way up should shut the choke, if you can look into the intake of the carb to see if the butterfly is shut and if not loosen the cable sheath clamp and side the cable until it does shut it and make sure the lever is still in the full throttle position
May 30, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
Lawn mower starts but makes a put put sound and runs for only 5-10 seconds i have cleaned carb bowl replaced fuel line replaced priming bulb and replaced air filter
I hope this helps you. :
http://www.fixya.com/support/r8367428-starts_dies_common_engine_problem
I would recommend using carburetor cleaner and flush out the jets.
Joe
Mar 23, 2011 | Briggs & Stratton Briggs Stratton...
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
Shuts right down after starting , when i prime it , it just makes a hissing sound
If it started and ran well already this season, then it is probably some blockage in the carb. Does it have gas? If you prime it and it starts and dies, it is most likely the carb or float. You have to take the carb off disassemble and clean it out. It is either some debris in the main jet or a stuck float valve. Clean things up with carb cleaner and put it all back together. Should operate fine them. Good luck.
Jun 14, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Mower starts fine but won't stay running. I have
Have you checked to make sure the jet in the carburetor is cleaned out. If the mower starts with primed fuel but shuts off after that fuel is burned out, you have some blockage not allow fuel in to the intake.
HTH
Good Day.
Oct 27, 2009 | Garden
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
Toro Lawn Mower With Toro Power Tools Logo
124 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
