Question about Targus Chill Mat PA248U Laptop Cooler
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
  • 1,675 Answers
Hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Posted on Oct 02, 2010
    Guru:
  • 1,082 Answers
Http://www.targus.com/us/product_details.aspx?sku=511-0050-001A
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Testimonial: "Thank you very much. Just what I needed."
    New Friend:
Does not help me needing a usb plug that goes into my laptop to run the fans.
Posted on Sep 19, 2016
  • Balthazar Hunglowus
    Balthazar Hunglowus Sep 19, 2016
    Useless when I need the USB plug to run the fans as I searched in google & found this "awnser" ...
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Jan 15, 2015 | Targus PA248U AWE01US Chill Mat and four...
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
I got a Targus PA248U Notebook Chill Pad, the part inside where I plug the cable in is messed up I think and it won't power on. How do I open it up to have a look to see if I can fix it?
I opened the case and hard wired the power cord directly to the wires of the fans. There are 4 philips-head screws at the four top corners under the rubber adhesive pads. Separate the top from the bottom. Two wires come from each of the fans. Cut and twist the two positive wires together and the two negative wires together. Cut the end off the power cord that is NOT the USB end and strip the wire insulation back. You will find a white insulated wire surrounded by another wire. Twist the ends of each separately making sure they are separated by the white insulation. Remove the circuit board using the tiny screws where the switch is and put the power cord end through the switch hole. Tie a knot in the cord to prevent cord from pulling out. Make sure the USB end can reach a USB port on your computer. Carefully test which wires to twist together by touching each to see if the fans turn. One way will work and other way won't. When sure of correct wires, you can solder them together and insulate properly with small wire nuts or electrical tape. Reassemble case with screws and plug in USB cord end when you want the fans to cool your notebook computer. I hope that this helps.
Jan 20, 2011 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat. I keep getting error with windows 7 that the device is not working properly. It operates but an error keeps popping up every 10 seconds. So I can not use it. What is the fix?
Belkin makes a surge plug that has usb powered ports.
this is a Gr8 option it takes the poering off the pc.
this should fix ya up.
Good Luck
Happy Computing
Jan 10, 2010 | Targus AWE19US Chill Mat XC for Laptops
Targus notebook cooling chill mat. One fan has stopped running after less than 2 months. Can you help
I have the same problem, and I looked inside to see the cause- the interior part for the power is poorly made and comes loose. That's the reason for the one fan not working and it getting weak. Sometimes wiggling the cord or trying to stabilize it will help. But, as I learned the hard way, it will eventually break. Its a poorly made product, and I've had mine about 4 months now and it completely broke today. I opened it and did my best to stabilize the part, but... it will break. As best as I can tell, its a poorly made product and there is no permanent solution.
Sep 28, 2008 | Targus Chill Mat PA248U Laptop Cooler
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
Targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Oct 30, 2007 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
3,311 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
