Question about Toro Lawn Mower With Toro Power Tools
It will start and run for a second and then shut off.
    Problem Solver:
  • 5 Answers
What is the model number of the mower and the model and type number stamped on the engine? Usually this is caused by old stale gas. The carburetor may need cleaning.
Posted on Oct 03, 2010
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
Sanyo PLC-XT10A shuts off after 30 seconds
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Dec 08, 2012 | Sanyo PLC-XT10A
Generac xl 4000 will not keep running after starting
try disconnecting the wire going to the low oil switch. if it runs then you need a new switch.
Sep 02, 2017 | Generac Electrical Supplies
Truck starts runs for a second shuts off .
The fuelpump is primed by the oil pressure switch.When the fuel pressure reaches normal PSI the computer shuts that pressure switch off and turns thepoweron to the fuelpump relay.You have a bad fuel pump relay
Jun 02, 2010 | 1994 Mazda 2WD B Series Pickup
Starts and runs 3-5 seconds and shuts down
Sounds like your security system is shutting the car down. You should be able to leave the key on for 15 minutes and it will reset itself. Make sure you are using factory keys, and they are in good condition.
May 28, 2009 | 2002 Pontiac Grand Prix
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Toro Lawn Mower With Toro Power Tools Logo
97 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
