Question about RCA D52W19 52" Rear Projection Television
Rca hidef tv
Mod & ser # 752w15byx1; e232c306s tv started coming on real slow especially in the am, a little bit faster during the day. Light on front goes out when you try to power up then after a little while the tv will eventually power up.
  • Grampy24 Jun 17, 2008
    I have not fixed this problem yet but have moved the tv from inlaws house to mine so I now know more about what is going on. After being off for an extended period of time, say over nite, when the power button is pushed the green lite on front turns on and a sound like it is going to come on is audible but the lite goes out and nothing happens. This happens three times then if you push the power button again nothing happens. If you wait about 1 minute or so then push the power again it will go thru the same cycle as above. After several attempts it will eventually turn on and everything seems to work good until the following day. Hope this gives a good idea about the problem. Thanks again.
    President:
  • 1,284 Answers
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
Posted on Jun 26, 2008
My 7-yr-old sony wega keeps restarting; blinks 30 times then video comes back on
Two things here to suggest: one is lamp life is 2000 hours or two years average--and many lamps that fail will either dim just a bit, take a bit longer than did to come up to full brightness and the set may detect that and try to blank the screen.
I am saying a lamp even if lamp light does not come on may be the problem or not.
Second, and I have seen this a lot, the fans in the set intake air in the front of the unit and exhaust it out the rear and no matter how clean the house is dust will get pulled inside.
Fans and air-path's can get coated with dust. Especially the blades on the fans, if a fan slows down just a little because of dust on its blades the set will also detect it as it monitors fan speeds etc.
A good dusting out with compressed air (try not to blow the dust into the screen area) will either confirm this or eliminate it as the problem. I almost always do it in the garage or outside as it may look like a dust storm when you do it.
These are my thoughts and I hope they may help you resolve your problem.
SD TECH
Dec 16, 2012 | Televison & Video
Picture tube will not come on.... rca mod f35731 mb chassis ctc169j56 ser 707261399h green light comes on but no picture.... help fuse?> bad picture tube...?
Bad grounds on the power supply are common on these TVs. The power supply will have the flyback transformer. Resolder the flyback, horizontal driver transformer, power resistors etc. Check and study the vertical IC and see if the pins will need resoldering as well. Inspect the small board that is connected to the CRT, and solder this, as necessary. This is a good start for repair, thanks for asking and show all hands of support!
Jul 28, 2011 | RCA Televison & Video
I have an RCA rear projection TV MOD: D52W19B SER: E315C30GD Chassis: ITC222. The flyback arcs when power is applied, several days ago the TV was operational, a loud pop emitted from TV, I unplugged it and...
yes it is a flyback transfomer is a very sensitive piece of equipment also known as a lot or lopt in you case i would say that the case has cracked on your flyback you may get by however if the damage inside is not significant yet be wrapping the flyback transformer in black electricians tape but this should not be a permanent solution
Jan 22, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 27 NO PIC / SOUND - Binking green light
I ouldn't find any good news on the web about this,
so i did a bit of research and discovered that it wouldn't cost me much more than the cost of repair if I went to Best Buy and bought a new HD-TV.
Wow ! The prices have really come down !
Now I'm glad that it malfunctioned !
Oct 20, 2009 | RCA F27TF700 27" TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Nissan sentra ser spec v
free the engine from the compressor and then remove the plug then first insert the drive belt on the smaller pulley side and after that try inserting the belt on the larger pulley side slowly by rotating the pulley slowly by stretching the belt with a rope
Jun 09, 2008 | 2005 Nissan Sentra
Tv will not come on
Bad flyback transformer part # 257807 possible damage to horiz out xistor # 237470...change transformer first,then xistor if you
must.....no generic....OEM quality only........T.
Mar 10, 2008 | RCA 36F530T 36" TV
Whirlpool wm 1000 semi pro washing machine
if you can give a more complete mod # i can help you on the front loaders its a slow drain time the mod # you gave me dont come up look on the lid or the back of the control panel for ser plate http://www.whirlpool.com/custserv/index.jsp try here for manual
Dec 28, 2007 | Washing Machines
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
