Question about Whirlpool Duet GHW9150P Front Load Washer
It stops washing and says "SUDS" then F35. - Whirlpool Duet GHW9150P Front Load Washer
    Genius:
  • 1,416 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks for visiting .
    Posted on Oct 02, 2010
    Whirlpool duet f35 error-suds error
    Maybe this will help, but I'm not sure
    Condition:
    SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
    The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
    Check:
    If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
    Check the drain hose and make sure it is not plugged or kinked.
    Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
    Check/Clean Drain Pump Filter of foreign objects
    Check Drain Pump
    Check Pressure Switch
    Check CCU
    Dado
    Sep 13, 2015 | Whirlpool Washing Machines
    SUD AND F-35 PROBLEM
    SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
    As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
    Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
    Suds, and F35 keeps coming up when trying to wash!
    I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
    Jul 26, 2010 | Kenmore 44102 Front Load Washer
    Error f35? What's the fix?
    They can and fixed my washer today! The fix was the replacement of a switch. The item # was W10156252 for my washer. It is called a switch-WL. Item # may be different for your model. I was getting SUDS and F35 errors. To install it you just remove the top part of the washer and should be located at the upper right-hand side, attached to a black hose. The switch has a small computer board. The price of the swith is around $130. Fortunately I bought a 3-year warranty on my washer.
    Apr 18, 2010 | Kenmore Elite HE5t Washer
    Message sud and f35 causing washer to stop washing
    don't panic/ suds is just what is you have / look in the window. do you see suds/ ok if door is unlocked poor into tub two lids of fabric softner . mixed with a quart of water . wait over night . and everything will be ok . f35 ?? it will probably go away also . if it does not get back with me. . no to stop this from happing again cut down the amount of dergt. or change to the proper type like H E .. hope this helps / ps remove the front panel 3 screws and on the left side remove the drain clean out .. this will help a great deal ..mm feed back please ..mm
    Dec 17, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
    Keep getting f35 code on quiet pak 9 washer
    F35,= SUDS
    set a few washes without using any soap to flush the pump out.
    Use less detergent and use a liquid rather than powder.
    Aug 25, 2009 | Kenmore Washing Machines
    My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
    Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
    Aug 02, 2009 | Kenmore Washing Machines
    F35 Message on Brand New Washer
    suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
    Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    48 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
