Question about Dell Inspiron 6000 Notebook
Dell inspiron 6000 power cord connection
The power cord itself is fine, the inside connection doesn't work unless you fiddle with the jack, etc. Very annoying, as Dell doesn't seem too concerned about it.
  • 1 more comment
  • kgj38 May 27, 2008
    I actually went ahead and ordered a dc jack replacement. Hopefully that will not be too scary of an install. Your answer was very concise and helpful. Thank you!
  • kgj38 May 31, 2008
    It was harder than I thought it would be. I think I killed my daughter's laptop! Oh well.
  • Anonymous Jan 09, 2009
    I have the same damn problem man!
    In fact everyone who owns Inspiron 6000, will and are having this damn problem!
    I managed to take apart the damn laptop, but what to do with the connector? It can't be removed, there's no way to solder it, there's a diode blocking the back way etc etc:/
    An expert whose answer gotĀ voted for 100 times.
  • 156 Answers
I am afraid it is going to be a a bit of work taking the laptop apart, solder the power jack than put back together.
If you are not confident to doing it i suggest you seek help by having a repair shop/centre service it for you. If the laptop is under warranty, you are better of raising a warranty call.
Anyway, you will need some screw drivers; small Flat and a Philips heads. You will also need soldering iron and lead. Finally, a work table will make things easier.
Check Replacing the System Board for help access the system board. Check and solder yo the power jack carefully and reverse the steps to put the laptop together.
Let me know how you get on.
Posted on May 27, 2008
My external audio connection doesn't work
Are you using the headphones jack? Do headphones work from the port? Win XP Drivers can be found here:
Nov 29, 2012 | Dell Inspiron 6000 Notebook
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Dell inspiron elec cord isn't firm so power turns off
Maybe it's the DC Jack that the power cord plugs into. If the jack is loose then you will experience the issue you are having.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 18, 2012 | Dell Inspiron 1525 Notebook
Bad power cord or bad connection on laptop?
Probably the DC Power Jack which is where the power cord plugs into the computer. Take a ink pen and stick the tip in where the power cord goes to see if it wiggles. If so, that's your problem.
Mar 31, 2012 | Dell Inspiron Mini 1012 Netbook
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
Jan 04, 2011 | Dell Inspiron 6000 Notebook
My dell computer connection seems bad. The power
i think u need a new power cord , y not taking it to a IT store
Apr 15, 2010 | Dell Inspiron 6000 Notebook
Problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
Mar 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Sound thru tv
You will need a cord that plus into the headphone jack or speaker out jack on the computer and has rca end to plug into the audio input on the TV.It will look like the one pictured.Please rate this solution.
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000, charging AC problems
This sounds as if the jack in the machine is loose or broken. Take a small screwdriver, place it in the jack, and see if there is any play in the jack. If there is play then you know the jack is loose/broken. I would suggest checking it or having someone check it. A loose or broken jack can create an electrical arch that can do severe damage to the machine, so if it is the jack, you will want to get it fixed ASAP. I also suggest not using the machine, if possible, until the jack is checked out. If it turns out not to be the jack, then it's going to be a problem with the power management system, and this is a major fix. From what you've posted, I'm going to say that it's the jack, and repairing the jack will fix your problem. If you have anymore questions feel free to ask.
Aug 08, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Update laptop bios go check for update of your laptop model....
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
1,262 people viewed this question
Alun Cox
