Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Bissell 9400 ProHeat Upright Upholstery Hose
I can not figure out how to use the upholstery hose on the Bissell 9400 ProHeat Upright. I have tried every button I can find but nothing seems to work. Help me!
    President:
  • 1,673 Answers
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
Posted on May 26, 2008
Where do I hook up the hose on a Bissell #7901-R?
Hey Anne! The upholstery hose wraps around on the back of your machine. Page six in the user guide shows how the hose wraps around.
If you don't have the user guide, here's a quick link to downloading one:
http://www.bissell.com/assets/0/132/134/228/123752ca-06aa-46a1-b90d-05287809b5c1.pdf?cid=ccsocial
Feb 19, 2013 | Bissell 7901-R Clearview Proheat Plus...
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell spray to floor not operating. Spray to upholstery fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
urr
Jan 01, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not getting sucktion to the hose. not picking up dirty water
heatman101
7t897
Dec 22, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Putting on the upholstery tool on the bissell proheat 2x
heatman101
Nov 14, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x upright 12 amps
heatman101
dfasdf
Jul 10, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
No water from my Bissell
I AM BISSELL WARRENTY DEALER, AND MOST COMMON PROBLEM WITH THESE UNITS ARE CLOGGS IN THE LINES AFTER THE HEATER OR IN THE HEATER THEM SELFS VERY DIFFICULT TO GET INTO. THE PUMP IS A DIRECT DRIVE WITH NO BELT AND I HAVE NEVER HAD TO REPLACE ONE NOT TO SAY ITS NOT THE PROBLEM BUT UNLIKELY IF AT ALL POSSIBLE TRY TO GET SOME FLOW AND TRY RUNNING SOME SORT OF LIME AWAY CLEANER INTO SYSTEM AND LET SIT THIS WILL HELP PREVENT CLOGGS AND POSSIBLY CLEAR CLOG OTHER WISE YOU WILL HAVE TO DISSASSEMBLY MACHINE AND CLEAR HEATER AND LINES MANUALLY. IF YOU GET WATER TO ATTACHMENT HOSE BUT NOT NOZZLE YOU MAY CHECK THE RED TIPS FOR CLOGGS. THESE CAN BE REMOVED WITH OUT TAKING THE MACHINE APART.
Mar 30, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Hose Attachment
On the clean / dirty water tank there is a red lint lint filter, this is on the upper part of the tank,
If this is blocked it reduces the suction ,this must be free from debris,
If you are using the turbo brush ,
there is a sliding switch on the brush, This diverts the suction from the brush to the nozzle of the attachment ,
You should see the dirty water traveling up the hose ,
You should only use bissells own cleaning solution as using another product would null your guarantee
Jun 11, 2007 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
317 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
