Question about SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive
I HAVE A SCRAP BOOK PROGRAM AND I PUT THEM ON THE FLASH DRIVER NOW I WANT TO TAKE IT AND PRINT THEM OUT BUT THEY DID NOT SHOW UP ON THE PRINT MACHINE HOW DO I GET THEM TO PRINT
    President:
  • 2,571 Answers
Please do not use capitals for the whole message, it is considered shouting and rude.
Your printer can only print files and photo's, it wont be able to recognise projects from a software program, print them directly from the PC
Posted on Oct 02, 2010
Ve 2512 printer can adjust machine to print 4x6photo. Print picture on 81/2 /11 only
What photo editing software program are you using? Photo dimensions are usually set in software. You can set what size paper you want in the printer setup section of the printer driver.
Aug 12, 2016 | HP LJ472UTABA Notebook - Elitebook 8460p...
Cannot remove the paper jam
To clear the message Paper Jam from the display, follow the steps listed below:
NOTE: images shown below are from a representative product and may differ from your Brother machine.
STEP A. Check for and remove any jammed paper or foreign objects in the machine
  1. Unplug the Brother machine from the power outlet.
    Caution Before you unplug the machine from the power source, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  2. Lift the scanner cover using the plastic tabs or finger holds, located on the left and right side of the machine until it locks securely into the open position.
    Caution DO NOT touch the encoder strip. The encoder strip is a clear plastic strip in front of the white vinyl band (outlined in red as shown in the picture below). If the encoder gets markings or debris on its surface, it may cause other problems.
  3. Verify the location of the print head. The print head is a black square object, located behind the encoder strip. The print head moves from left to right.
  4. Move the print head to the middle using your fingers.
    Caution DO NOT touch the encoder strip (marked in red shown below).
  5. Check for and remove any ripped paper or a foreign object in the left corners or underneath the print head.
    Hint The ripped paper may be very small. Using a flashlight will help you to find the ripped paper.
  6. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper.
  7. Close the Jam Clear Cover. Make sure the cover is closed properly.
  8. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
  9. Remove the paper tray (1) from the machine.
  10. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
  11. Using your hand, lift the front of the machine approximately 6 inches off the surface.
  12. Look inside the tray areas roof of the machine and a row of black rollers will be aligned across. See picture below.
  13. Look in-between each of the black exit rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
  14. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
  15. Place the machine gently down onto the surface.
    • If no paper scraps were found inside the machine, please check the paper in the tray. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper in the tray must be replaced and continue to STEP 16.
    • If paper scraps were found and removed from the machine, continue to STEP 16.
  16. Put the paper tray back into the machine.
  17. Plug the power cord back into the power outlet.
    • If the LCD displays the date and time, go to STEP D.
    • If LCD displays the message "Paper Jam" go to STEP B.
- If the print head is on the right side:
  1. Plug the power cord back into the power outlet and wait for the machine to stop making noises.
  2. Press the Stop/Exit key for approximately 5 seconds until the print head moves to the middle.
  3. Unplug the machine from the power outlet.
    Caution Make sure to unplug the machine. The print head may move and injure your hand. Before you unplug the machine, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  4. Examine the right side of the machine where the print head had been positioned and underneath the print head and remove any pieces of ripped paper or foreign objects.
    Tweezers may be used with caution to remove paper scraps or the foreign objects.
  5. After confirm the paper scraps or the foreign objects in the right corners or underneath the print head, go to STEP 6.
Mar 10, 2011 | Brother MFC255CW All-in-One InkJet Printer
I want to install driver after formatting my note book.
hi so it s very simple,juste yiu should have internet,same you with a flash disk wifi external and go to the site of market of your note book. or go to this site www.touslesdrivers.com,after click my driver,in the bellow lunch detection(lancer la detection),install my config and this program will detected all your hardware and give you the driver proper for all peripherals.
Feb 23, 2011 | Miltope TSC-750M Notebook
Please advise what you charge for solving following problem:\r\n"Paper jam on Brother MFC-260C:Following Brother User's Guide, I removed the Jam Clear Cover, and pulled out jammed paper, but got only...
1. Unplug machines power cord from the power outlet. 2. Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position. 4c89ecbe03c0173ae1000000cd8620c6.gif 3. Remove all of the paper scraps stuck inside the machine. NOTE: The print head can be moved manually with hand to assist with removing all of the paper scraps. 4c89ed1103c0173ae1000000cd8620c6.gif
4. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper. Then close the Jam Clear Cover (1).
5. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
6. Remove the paper tray from the machine.
7. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
8. Using your hand, lift the front of the machine approximately 6 inches off the surface.
9. Look inside the tray areas roof of the machine and you should see a row of black rollers. See picture below.
10. Look in-between each of the black rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
11. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
12. Place the machine gently down onto the surface.
- If paper scraps were found and removed from the machine, continue to STEP 13.
- If no paper scraps were found inside the machine, the paper in the tray may be causing the issue. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper must be replaced.
- If you do not have replacement paper, follow the rest of this solution, after you have replaced the paper.
- If you replaced the paper, continue to STEP 13.
13. Put the paper tray back into the machine.
Dec 18, 2010 | Brother Office Equipment & Supplies
Help! My Dell Inspiron E1505 laptop won't print
If you are using XP home or pro. Use add remove programs icon in your control panel to completely remove the driver. Then check add remove printers to make sure it is gone.
Go to www.download.com search for ccleaner, download the one with the highest # of downloads.
Load the program, I select no to check for updates one less thing causing traffic.
Run the program DO NOT use the cleaner portion until you know how to. It could wipe bookmarks and other browser info. Great program, but can cause harm if not used correctly.
Then select reg tool and it will ask you to make a back up. I have used this reg tool many times and never had it fail but back it up anyways. It will show you 100's to 1000's of problems just click fix selected items and it will run. Repeat this again and less problems with show this time. then reboot and reload the driver.---Hope this info helps.
Jul 26, 2010 | Dell Inspiron™ E1505 PC Notebook
I have a relatively new Toshiba which has windows vista. I've installed Print workshop 2008 and everytime I try to add a new sheet to create a book for a scrap book I receive An unhandled exception has...
Hate to say it, because I use Vista myself, but it seems that the program "Print Worshop 2008" not really that compatible with Vista...even though they claim that it will work fine. Just another compatibility bug within the two programs. Try first updating your system with all patches, and service packs, or download 2009 version of Print Workshop. I would also try contacting Valusoft.(Valusoft.com). Ask them to send you the newest version (they should send it to you for free if you bought the older version and it is not working)
Aug 13, 2009 | ValuSoft Print Workshop 2003 for PC
NAND FLASH ROM ERROR IA CODE CHECK SUM
Update Firmware on machine to latest level ,you will need the print driver and scanner driver installed
use the USB connection
Here is a link to the ftp site for firmware download
ftp://ftp.minolta-qms.com/pub/drivers/other/MC2490MF/
There is apdf that explains how to update the firmware correctly
to get started turn on machine with the menu key held down the display will change to BIOS mode
then send firmware from program downloaded
Nov 21, 2008 | Konica Minolta magicolor 2490MF Laser...
Instrution book for 8860 DN
I have a Brother MFC 8860DN Network Fax machine and I need to program some phone numbers on it for automatic fax. I don't have the book to follow the steps to program it.
Nov 21, 2007 | Brother Office Equipment & Supplies
Print
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges. Manually Cleaning Inside the Printer Steps: 1. Unplug the printer from the surge suppressor. 2. Remove the internal paper trays. 3. Remove the toner cartridge and place it on a piece of scrap paper. 4. Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer). 5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided. 6. Wipe away dust and spilled toner. Remove paper fragments. 7. Clean the rollers, but don't touch the sponge roller. 8. Replace the toner cartridge. Tips: To remove unfused toner from the rollers following a paper jam, print 5 to 10 blank pages on scrap paper. Wipe toner from clothing if necessary, then immediately wash toner-soiled clothes in cold water. Go to your printer manufacturer's Web site (see Related Sites) for detailed cleaning instructions. Warnings: Don't use any liquid cleaners inside the printer. Initiating Automatic Cleaning Through Printer Software Steps: 1. Open the printer software by double-clicking on a printer icon or specific printer utility program, or opening a document and then selecting Print from the File menu. 2. In the printer software, look for a button labeled Options, Troubleshooting, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.) 3. Follow the instructions on the screen. 4. Repeat the cleaning process if the results aren't satisfactory.
Jan 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Logo
29 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
