Question about Maytag Washing Machines
MY WASHING MACHINE WILL LOAD THE WATER BUT THEN IT STOPS (WONT SPIN)
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks.
    Posted on Oct 02, 2010
    Kenmore top load washing machine stops cycle wont drain water
    Amber, you probably have a broken lid switch. They will not let the machine go into drain and spin because it thinks that the lid is open.
    Aug 13, 2014 | Washing Machines
    Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Apr 21, 2011 | GE Washing Machines
    Wont spin out,starts spin cycle then stops
    heatman101
    Sep 25, 2010 | GE WWSE5200B Top Load Washer
    Washing machine wont rinse or spin
    it fills up with water but it won't spin and then makes like a grinding noise someone told me it could be a clutch
    Aug 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing machine does not spin
    Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
    Twin machine wont spin
    the lid swich is defective,,,on the right hand side push down on the little switch with a non metal probe ..listen for a click..if no click or you have to push to far down change lid switch
    Oct 13, 2008 | Whirlpool LTE5243D Top Load Stacked...
    Kenmore Washine Machine does not drain
    sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
    Mar 10, 2008 | Washing Machines
    Washing Machines Logo
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
