I have a 2002 Whirpool Top Load "Catalyst" clothes washer that works perfectly....except for the fact that it makes a loud clicking or ratchet type noise at the start of every spin cycle. It appears as if the noise starts before the clutch engages. I have replaced the coupler, so that is not the issue. Any suggestions? As I said, except for the noise, it works perfect. One other fact, though not totally reliable, is that the noise sounds like it is originating from the top left (facing the washer) rear portion of the unit. Thanks
  • 3 more comments
  • dcmajapan Oct 02, 2010
    Too many possibles....to ad some more detail, the clicking/ratcheting noise is LOUD....and starts before the drum starts spinning, and will continue while the drum is spinning with no real pattern...sometimes shorter, sometimes longer.
    Can anyone narrow this down? Based on the info I have so far my best option is to buy new and junk this machine once it finally craps out.
  • dcmajapan Oct 04, 2010
    Okay, I will pull the washer apart tonight, but I purposely did some "listening," and the noise is definately eminating from the top left (facing washer) rear area of the washer. What mechanical items are there in that area that can produce a loud ratceting sound only before and during the spin cycle???? Thanks
    I have definately isolated the sound to the top left (facing the washer) rear panel area. What mechanical device in that area could be the problem? Thanks
  • dcmajapan Oct 05, 2010
    Okay....assume this is a troubleshooting step to isolate the noise source?
    President:
  • 1,554 Answers
Disconnect power then remove the two Phillips-head screws securing the lower left and right rear corners of the console to the washer top. Tilt the console back on the hinges that secure the top of the console to the washer back.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cI have a 2002 Whirpool - 4e2277c.jpg/>4e2277c.jpg
Rotate the access cover on the washer top clockwise to expose the hose assemblies underneath and disconnect the bleach dispenser venturi hoses and the detergent I have a 2002 Whirpool - 71dc53c.jpgsoftener inlet hoses.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the caI have a 2002 Whirpool - 8557e5b.jpgthe tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and set it aside. You can now visually inspect the washer and find the source of the clicking noise. Jump a wire between the wires of the lid switch connector on the console side to make the washer run.
Bring the cabinet to the front of the washer when reinstalling then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Oct 04, 2010
  • Jahn27
    Jahn27 Oct 05, 2010
    Certainly to isolate the noise source.
  • Washing Mach... Master
  • 17,129 Answers
What can be done to finalise the source of the fault is to disconnect the power of the unit. Now disconnect the motor from the control panel connecctions.
Checking hte voltage on the motor apply a voltage so as to simulate the drive, be careful when you do this and do not lett your hands in as the motor rotates. You can now hear/see the source of noise as the mtoro is engaged or disengaged.
If there is a geared drive to the spin cycle to increase the RPM then it is possible that the unit be taken out and overhauled , to be greased and set back.
If not this can be the start of the spin which can be a drive slipping.
Reccify and reconnect the motor connection back.
Posted on Oct 03, 2010
  • 2,272 Answers
Did you checked the lid switch.In some cases the lid switch gets short and this causes the clicking noise.If the lid switch is faulty the spin cycle will not start.But if the lid switch is getting short then spin cycle will work but such clicking noise occurs. But if the lid switch checked ok then the other possibility is motor coupler,in your case the coupler is replaced,the other possibility for such noise before spin cycle is problem in clutch or problem in transmission or transmission pulley.As you mentioned the noise comes before the clutch engages,but still check the transmission and transmission pulley. ------------------- If the spin basket is spinning back and fourth during agitation the sifter coil is bad. When the sifter coil is bad and the spin basket is turning during wash the bottom shipping brace will hit one another this will make a loud click each time the motor changes directions during wash.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 02, 2010
  • raj somaiya
    raj somaiya Oct 02, 2010
    Usually you get 2 springs holding the top of the drum. If either spring reaches the point where it momentarily stops being in tension, it makes a hell of a noise, out of
    all proportion to its little size.
    There should be two springs from
    the top of the drum, one to the front of the machine and one to the back.Check both this springs.
    Also one more possibility.Check the drain pump and drain hose.If there is any thing got stuck like single metal nail or some coins or any thing like that,then this will make the noise .Check the pump and hose for drain.Confirm that there is no such blockage.
    Thanks for keeping updated with the query.
  • raj somaiya
    Check the spring holding on the drum.If this springs are loose or out of its fitting then refit it.
    check the drain pump and hose assembly.
    Keep updated.Thanks.
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
I have a GE Clothes Washer WBSR3140G2ww when the washer machine starts it agitation there is a loud scraping sound to the left side of the machine. What are the possible problems associated with this...
I have the exact same unit in a 2nd home we just purchased and when the repair guy came, he said "it was in perfect working condition". Mine also has next to no agitation, I think a goldfish swimming around in a bowl makes more motion. I absolutely hate this washer and will replace it asap.
Nov 02, 2010 | GE WBSR3140DW Top Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
My washer is making a loud, clicking noise
One of them underwire garments could be stuck in the pump and eating a hole into it.You should take the cover off and take a look at it in motion without the case.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
WHIRLPOOL WASHER MAKES A LOUD RATCHETING SOUND
CALL YOUR REPAIRMAN AND SEE IF HE CAN FIX YOUR WASHER FOR YOU. IF NOT, THEN IT IS TIME TO BUY A NEW WASHER. GOOD LUCK.
RODNEY
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Loud clicking while agitating
You may have debris stuck in the pump.
This can cause the clicking sound and also bind the pump causing a circuit overload.
Feb 21, 2009 | Whirlpool WTW5550S Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
I have a problem with my Whirlpool washer (top load). It seems that when a load of wash is finished and I reach in to unload, the clothes are still very wet, almost soaked. I am guessing the spin cycle...
Try this site, it is very helpful by showing video of step by step instructions.
youtube.com
In the search box type in repairing whirpool washers
Click on appropiate video(s), i'm sure u will find it helpful.
Plz rate this solution.
Thanks.
Dec 31, 2008 | Washing Machines
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Dec 11, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
