Question about Yard Machines 50 Torque 2in1 22" Push Lawn Mower with High Wheels ()
After primed, mower starts well, runs for about 2-3 seconds then dies
I just fixed my mower today after almost giving up on it. It would start, then stop after about 1 or 2 seconds after priming it. So I knew it wasn't getting fuel after starting. I first tried the standard things such as checking gas cap for venting, I removed the cap and tried, but same problem. I checked the fuel line from tank to carb, but it was OK.
So then I removed the carburator and cleaned all over, sticking a pin in the little jets on the bolt holding the bulb. I pounded it all over with carb cleaner even though everything looked very clean, nothing appeared to be dirty and no visible problems.
Then I noticed that the float as I tipped the carb up and down didn't always go down. Then I used WD-40 to blast the hinge / springs around the float. I reassembled the carb, air intake, and fuel tank back on to the mower and tried it. It worked and saved me a few hundred that I was ready to spend on a new mower.
When primed, fuel is forced into the carburator so it started right up, but since the float was sticking in the UP position, it though there was already fuel in the bulb and this didn't allow more fuel from flowing into the carburator from the tank. The mower is about 8 years old, Tucumseh, but this will let it last me a few more years.
Posted on Apr 16, 2011
  • Yard Machines Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 03, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Lawnmower starts when primed only then stops
All mowers have a low oil cutoff. Fill oil. 30w.
May 29, 2013 | Garden
I have a Sears (Craftsman) mower model # 944.368300. When I prime it, and attempt to start it, it runs for approximately 5 seconds and then dies. If I hold the primer button in, the mower keeps running. ...
Try removing the brass bolt that holds the float bowl to the carb on and cleaning it thoroughly. This bolt is the main jet for the carb and can become clogged with varnish or debris esp. if no inline filter is used or gas is allowed to evaporate in the carb. There will be small holes on the bottom and the sides where there are no threads. If no other problems, this should cure the 5 second run.
Please vote on this solution.
Sep 04, 2010 | Craftsman Air Filter 33021 2 pk for Lawn...
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Starts when primed but dies...
check your gas cap, try running it without your gas cap on and see if that helps if so id either replace it or drill a really small hole in the top as modern engines the fuel is gravity fed into the carb
Jul 13, 2009 | Craftsman Garden
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 50 Torque 2in1 22" Push Lawn Mower with High Wheels () Logo
287 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
