Question about LG WM0642H
The washer would not drain and when entering test mode the washer displays nE (or possibly upside down uE). I have replaced the main board for the washer and it still does the same thing
  • 15 more comments
  • dsargenfs Oct 07, 2010
    This happens when entering the QC test mode for the washer after replacing the main board and the sensor on the stator,
    I have replaced the main board on my LG HW0642HW washer and the sensor located on the stator and it will not spin, the motor just wants to hum, it will not pump water, I have removed the pump and applied 110VAC directly to the pump and it spins, I checked to make sure the fins were not damaged either which they weren't
    Thank you for that suggestion as I hadn't tried that. I have 123 VAC at the leads for the pump. When I hooked it back up it didn't pump any water out. I have also removed the drain hose from the washer in its entirety and there is nothing in the drain hose.
    it isn't a UE it is appears to be nE. There have been no clothes in the washer and I have replaced the hall sensor along with the main board
  • dsargenfs Oct 08, 2010
    how do I upload the picture to this thread?
    Hopefully I didn't send this more than once as I was expecting to see a attachment before sending and it doesn't appear to do that.
    I have the picture but apparently am unable to add it as this window does not have the option of including the picture
  • dsargenfs Oct 09, 2010
    The pictures can be found at mediafire and the link is
    http://www.mediafire.com/?t72o55swco006
    As I believe I mentioned earlier the parts people told me the part number for the main board is from a WM0642HS but the model number on the washer is WM0642HW which is shown in one of the pictures. The parts people originally sent the wrong board (sent the one for HW) and later sent the board to match the one in the washer. The two boards have different electrical connectors and have a slightly different layout
    if you cannot view the picturesthe user name for the account is dsargenfs. Your assistance is appreciated
    The washer will not drain or spin. When trying to enter the test mode the washer goes directly to error code nE and will not do anything other than power the machine down. I know that nE is an unknown error. I have replaced the main board and the machine will not drain and sporadically will allow me to enter the spin cycle in test mode and normal mode. I have checked the resistance on the motor terminal (all 3 read 7.6 or 7.7) within the specs for the part. I have replaced the sensor for the motor, connected 110VAc directly to the pump and watched the blades turn at a high speed, there is no damage to them. I have verified that there is 110VAC power coming to the pump.
    Per the parts company the part number for the main board is for a "WM0642HS" model (my washer ends with HW). They sent both boards to me and they have different electrical connectors and I needed the HS series board. The washer clearly has the HW model # on it.
    My LG washer ? model WM0642HW will not drain or spin. When trying to enter the test mode the washer goes directly to error code nE and will not do anything other than power the machine down. I know that nE is an unknown error. I have replaced the main board and the machine will not drain and sporadically will allow me to enter the spin cycle in test mode and normal mode. I have checked the resistance on the motor terminal (all 3 read 7.6 or 7.7) within the specs for the part. I have replaced the sensor for the motor, connected 110VAc directly to the pump and watched the blades turn at a high speed, there is no damage to them. I have verified that there is 110VAC power coming to the pump.
    Per the parts company the part number for the main board is for a ?WM0642HS? model (my washer ends with HW). They sent both boards to me and they have different electrical connectors and I needed the HS series board. The washer clearly has the HW on it
    the error code is a nE not a uE or UE, the problems are occuring with the machine empty
    My LG washer – model WM0642HW will not drain or spin. When trying to enter the test mode the washer goes directly to error code nE and will not do anything other than power the machine down. I know that nE is an unknown error. I have replaced the main board and the machine will not drain and sporadically will allow me to enter the spin cycle in test mode and normal mode. I have checked the resistance on the motor terminal (all 3 read 7.6 or 7.7) within the specs for the part. I have replaced the sensor for the motor, connected 110VAc directly to the pump and watched the blades turn at a high speed, there is no damage to them. I have verified that there is 110VAC power coming to the pump.
    Per the parts company the part number for the main board is for a “WM0642HS” model (my washer ends with HW). They sent both boards to me and they have different electrical connectors and I needed the HS series board. The washer clearly has the HW model # on it.
    you must not have read my post as I have a front load washer and I have removed the pump and hoses, there are no clogs, I have applied voltage directly to the pump which was turning the impeller, there were no damaged blades and have metered 110VAC coming to the pump. The door switch is working fine, There was more that I had posted explaining the symptoms,
  • dsargenfs Oct 10, 2010
    Per the parts company the part number for the main board is for a ?WM0642HS? model (my washer ends with HW). They sent both boards to me and they have different electrical connectors and I needed the HS series board. The washer clearly has the HW model # on it.
    it is not an unbalanced error. It is definitely not a uE or UE
    My LG washer - model WM0642HW will not drain or spin. When trying to enter the test mode the washer goes directly to error code nE and will not do anything other than power the machine down. I know that nE is an unknown error. I have replaced the main board and the machine will not drain and sporadically will allow me to enter the spin cycle in test mode and normal mode. I have checked the resistance on the motor terminal (all 3 read 7.6 or 7.7) within the specs for the part. I have replaced the sensor for the motor, connected 110VAc directly to the pump and watched the blades turn at a high speed, there is no damage to them. I have verified that there is 110VAC power coming to the pump.
    also I have replaced that sensor, no one can tell me what the nE error code is. and if you see in my previous email I replaced the main board also.I have tested the resistance on the pump coil and the motor coil each reads within the parameters of where they should be
  • 10,515 Answers
UE means that the unit is unbalanced. Take the clothes out and see if it spins without them, if so then it might just be an unbalanced load. If it acts up all the time then you will probably need to replace your hall sensor which is clipped onto the side of your stater motor on the back of your tub. You will need to remove the entire stater motor and disconnect the hall sensor to change it out. This is the device that relays information back to the control board to tell the unit if the load is balanced or not.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2010
  • 2 more comments
  • taran_2005
    taran_2005 Oct 07, 2010
    Thanks for your response!!
    There is no nE code on LG washers. If possible take a pic of the error code and upload so that we could have a look at it. There could be many codes resembling the same.
    Thanks!!
  • taran_2005
    taran_2005 Oct 08, 2010
    When you click on Add on Comment, below that box ( where you write your query ), there is a link for Pictures. You could upload the pic from there or you could use free upload sites like rapidshare or mediafire and then provide me with the link.
    Hope i helped you.
  • taran_2005
    I am sorry, i didn't get that. Have you got the pic of the same? I do not see any pic of the same.
    Hope i helped you.
  • taran_2005
    taran_2005 Oct 09, 2010
    Once you click reply on comment, you could see a box where you write the comment.There are few options below that box where you could change the font or add a video or picture or upload the pic on mediafire and copy the link to me.
    Thanks!!
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
what this code simply indicate is an error code that means (no entrance).
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose.
  • If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place.
  • The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts.
  • Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman.
  • Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • Hope this help?.
    Thank you and thanks foe using fixya.
    Posted on Oct 09, 2010
    • Oloyede Monsuru Oct 09, 2010
      What is the comment like.?
      Thanks once again.
    • 15,935 Answers
    UE = Unbalance Error
    The balance sensor is the likely culprit.
    CLICK HERE to see it.
    #351 in THIS DIAGRAM
    While you're in there - take a look at the vibration dampers - if one or to are damaged - it may cause this condition as well.
    Thanks!!
    Posted on Oct 10, 2010
    • 10,319 Answers
    You have an unbalanced drum'
    here is a LG website that will help you out here
    http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
      President:
    • 1,932 Answers
    An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not
    spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
    When this happens in small loads the cloth clump together and unbalances the drum. Normally it won't happen in small loads.
    When using mixed fabric loads this may happen. That is when washing jeans and t-shirt together as the jeans are heavy this may cause this error to occur.
    Just balance the load inside the drum and it will be fine
    Thank You
    • Udhaya Rajan
      Udhaya Rajan Oct 07, 2010
      Did you check how much power you getting in the terminal where you connect the drain pump.?
      Thank you
    • Udhaya Rajan
      Udhaya Rajan Oct 09, 2010
      The problem is with the pump only.When you put back the pump due to some misalignment the pump is not turning.so no draining of water taking place.I suggest you to replace the pump.
      You can order the part from below website
      http://www.searspartsdirect.com/partsdir...
    How to clear codes
    i found this in another place
    Quick Test Mode
    Note: This test erases all faults and memory:
    To enter press Spin, Soil, & Power
    simultaneously with the power off.
    1. All LED's light up and the washer beeps as it
    enters the Quick Test Mode.
    2. The unit displays the software version for a
    second then clears the EEprom.
    3. After the displaying the software version, LCD
    will display Model information.
    If EEEE is displayed the PCB assembly is defective.
    For production up to 03/31/2009 Serial **S3**
    4. When the version is displayed. Press the following
    keys to test the various components.
    Effective 4/1/2009 Serial **S4 ** a change was
    made.
    4. After the displaying the software version, turn
    the Jog dial CCW to display "F4". Press the following
    Press Temp Key to cycle through the Water Valves in
    this order: Cold Main, Bleach, Cold Main & Bleach for
    Fabric Softener, Hot, then off.
    Press Spin Key to test Motor circuit.
    Press Signal Key to test Drain Pump
    Press Soil to test door lock - unlock circuit
    Mar 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
    Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
    IE: Water level (246) was not reached in 8 minutes
    UE: Imbalance: Load too small, too large objects between tubs
    OE: Drain problem took longer than 10 minutes to drain
    FE: Overflow issue drain pump running to comp
    PE: pressure sensor (sensor out)
    dE: door error. open door. switch is out
    LE (with a a slash in the
    middle of L. Upside down F) Thermistor out
    CE: Over amping Too much soap wrong soap
    LE: hall sensor shorted/destroyed from sudslock
    bE: Ball sensor loose connection/out of order
    EE: eeprom out test mode only
    PF: power failure momentary interruption of shocktricity
    Service notes and manual
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Jul 23, 2011 | LG WM-2277HW Front Load Washer
    I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
    How to run a diagnostic test:
    1. Unplug power cord, then wait 30 seconds.
    2. After plugging in, follow these instructions...
    To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
    To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
    Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
    • "t01"
      Model ID
      Verifies (or sets on new board) the proper Model id
    • "t02"
      Error Codes
      Lists up to 10 control-detected problems
    • "t03"
      Software ID
      Verifies using latest Control-eePROM-lnverter software
    • "t04"
      Exercise lCD/lEDs
      Verifies that all the displays and buttons work
    • "tOS"
      Pump Test
      Tests drain-out pump
    • "t06"
      Pressure Switch Test
      Fills to all 3 levels, then pumps out water
    • "tOT'
      ThermistorlHeater Test
      Verifies that both the Thermistor and Heater work
    • "t10"
      Tumble Test
      Verifies Washer Tumbles (I.e. Wash cycle)
    • "t11"
      Spin Test
      Verifies Washer spins
    • "t12"
      Dispenser Test
      Verifies Dispenser fill works-for all four fill modes
    • "t13"
      EOl Test
      Performs End-of-Line test sequence
    Button Commands (based upon test mode)
    t01 prerequisites: none
    Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
    Power Returns to "t01"
    t02 prerequisites: none
    Start Displays most recent error code (EOO=none)
    Start Displays previous error code (up to previous 10)
    Hold start Clear all error codes (and then displays EOO)
    Power Returns to "102"
    t03 prerequisites: none
    Start Alternate "cod" and Control Software version
    Start Alternate "EE" and eePROM version
    Start Alternale "Inv" and Inverter Software version
    Power Returns to "103"
    t04 prerequisites: none
    Start loops on lighting lED's, LCD and cycle ids
    Any button Beeps when depressed
    Power Returns to "t04"
    tOS prerequisites: none
    Start Displays "P" and pump for 60 seconds
    Power Returns to "t05"
    t06 prerequisites: none
    Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
    Start Fill, when reaches Main level-displays "nl"
    Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
    Power Returns to "t06"
    t07 prerequisites: Main level pressure switch must work
    Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
    Power Pumps out water and returns to ''t07''
    t10 prerequisites: none
    Start Displays "It" and tumbles tub alternating the direction every 5 seconds
    Power Stops tumbling and returns to "t10"
    t11 prerequisites: none
    Start Spins to 400 RPM displaying increasing RPM
    Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
    Power Stops spinning and returns to "t11" when stops
    t12 prerequisites: none
    Start Displays "pdt" and fills via pre-wash chamber
    Start Displays "ddt" and fills via main wash chamber
    Start Displays "bdl" and fills via bleach chamber
    Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
    Power Pumps out water and returns to "t12"
    t13 prerequisites: none
    Start Starts EOl test sequence (NOT used in Repair)
    Power Returns to ''t13''
    Once you have the diagnostic codes, check this post for the meaning of the codes:
    http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
    Jun 25, 2011 | General Electric WCVH6800J Front Load...
    I have a DE code on my LG Wm1832cw front load washer. This happened last weekend, and we found that the small drain hose in the front was clogged so we got the clog out and the washer has worked great all...
    UE: Imbalance: Load too, small too large
    Service manual
    May 27, 2011 | LG WM-2277HW Front Load Washer
    My clothes were in the washer and when I went down to check there was an error code. LE The clothes were still wet, and appeared to not have gone through the rinse cycle.
    The LE is caused by over sudsing OR clothing trapped between the tubs. The LE: hall sensor shorted/destroyed from sudslock or clothes between tub. Correct the issue and party on.
    LG errors:
    PF: power failure momentary interuption of shocktricity
    LG service manuals and repair notes.
    Apr 17, 2011 | LG WM2487H Front Load Washer
    LG washer WM 2277HW Wont spin LE on control panel
    LG error codes:
    LG washer notes:
    Problem:
    An occasional LE error but always a slow or no spin.
    Solution:
    A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
    Your service manual and more LG washer notes HERE
    Mar 07, 2011 | LG WM-2277HW Front Load Washer
    Displays an LE error code - what does this mean and how do I fix it?
    Codes for LG/Kenmore washers:
    FYI:
    Nearly all brands of "HE" detergent have incorrect instructions.
    The correct amount is as follows:
    HE: (2) Tablespoons Per Wash load
    HE 2X (double concentrated) : (1) Tablespoon
    HE 3X (triple concentrated): (1) Teaspoon
    This reduces/prevents:
    1) Musty Odor
    2) "LE" Error/Interrupted Cycle
    3) L-O-N-G Cycle Times (longer than time displayed)
    4) Insufficient Cleaning Results
    5) Small Water Leaks from the air vent behind the washer or at the
    front door gasket
    6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
    7) Reduced Spin Speeds (laundry not spin-dried effectively)
    Also:
    Problem:
    An occasional LE error but always a slow or no spin: Solution:
    I have service manual and more here
    Jan 16, 2011 | Washing Machines
    LE code
    IE: Water level (246) was not reahed in 8 minutes
    middle of L. Upside down F) Thermister out
    WM-2277HW service manual and more HERE
    Thanks for using FixYa
    Jan 07, 2011 | LG WM-2277HW Front Load Washer
    The does not spin when put few clothes
    Some do not wash with a small amount of clothes. It is recommended to add more clothes. The idea is saving water and energy by not washing one thing at a time.
    Some various errors for front load washers:
    Dec 31, 2010 | Washing Machines
    Won't spin
    Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
    Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
    Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
    Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
    Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
    Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
    Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
    Mar 03, 2010 | Maytag Neptune MAH9700 Front Load Washer
    LG WM0642H Logo
    540 people viewed this question
    Top LG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
