Question about Brother LS-2125 Mechanical Sewing Machine
My machine won't sew thick material, even 2 layers of thin felt won't work. It just skips on the spot and won't move the material along. I've tried it with cottons and thin polyesters, so it's definitely the material that's making the difference. Any suggestions?
  • 4 Answers
SOURCE: machine skips stitches when sewing thru several layers of fabrics
Is your needle new? The needle needs to be replaced every 8 hours on a regular sewing machine, and the ULT benefits from even more frequent changes. Also try a bigger needle, if you're using a 75/11 move to a 90/14, make sure your needle matches what you're doing, you might not think those little needle tips differ much but they really do.
The manual also mentions if there is to much lint under the needle plate. Keep in mind all sewing machines need the bobbin area cleaned out every time you change the bobbin, but the ULT likes cleaning up down there about twice as often.
Posted on Nov 23, 2008
SOURCE: CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
This happened to me and I discovered that my presser foot was stuck up. (LOL) I was using embroidery and the needle was actually brushing against the raised presser foot. So, I turned machine off, removed embroidery part and checked the presser foot switch. It was not moving. Well, I put the machine on regular sewing and just turned the wheel a few times and the presser foot reset. When I went back to embroidery all was fine (and still is). so, check yours.
Posted on Dec 26, 2008
SOURCE: Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Posted on Oct 07, 2009
yeroc
  • 397 Answers
SOURCE: the stitches on the bottom of the material is
check tension by putting pressure foot down and seeing if your getting tension from thread...(lower and upper)
Posted on Dec 04, 2009
  • 415 Answers
SOURCE: I get skipped stitches when
Did you use a larger sized needle for the think fabric? It sounds like the needle isn't penitrating deep enough. You will need a larger needle size for the thick fabric and you might try slightly adjusting the tension tho a larger needle may be all you need. Make sure it is a sharp not a ballpt needle too (assuming you're not using polyester knits which isn't something one usually makes oven mitts with :) )
Posted on Mar 21, 2011
Testimonial: "Very pleased!!!!!!"
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
I sew thin leather w/Janome MC4000 using leather needle. Want to try thicker leather but not damage machine. How thick will this machine take?
Be careful sewing thick materials with a domestic machine. Even though a lot of machines are supposedly able to sew thick leather & fabrics, it could damage your machine in the long run. If you value your machine, you might want to find a second machine (used mechanicals, older Singers, etc., probably work better for this purpose) to sew thick fabric. Save your nice primary machine for more conventional uses.
Dec 13, 2015 | Sewing Machines
My machine skip stitches
Replace the needle it might be bend and check if it is the right needle for the work you are doing. You get for example stretch needles, denim needles, needle for thick/thin yarn, thick material ect. Using the wrong needle for the wrong material can cause skipped stiches especially if it did not do it before. Clean and oil the bobbin holder and make sure the bobbin is threaded correctly. Can also adjust top yarn tension as a last option.
Apr 09, 2015 | Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
My automatic buttonhole attachment won't make
This is not the problem of the thickness, but of the softness. Fleece will pull unevenly, causing the dogs to simply tug at layers of it in place, instead of moving it. You will have to (GENTLY) assist the dogs in moving your fabric, if your fabric is this soft.
The cause of this is 90% on the fault of the fabric, and 10% on the way the buttonholer foot works. The foot is built to hold the fabric fast in place, with sliding action only permitted by the buttonhole guide. However, this is assuming the dogs can get enough purchase to move the fabric around. Simply put, again, you will have to help the dogs along with this one(you will be able to clearly feel the difference and which way the dogs "Should" be moving at the time when you attempt to, as once it catches in one direction, it is likely to keep going in that direction until the dogs stop.)
Jan 24, 2010 | Singer 7444 Mechanical Sewing Machine
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
Skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
May 07, 2009 | Juki DDL-8700
Difficulty sewing quilt blocks
Try using a "walking foot" presser foot. It has feed dogs on the top to help all the layers go through evenly. A generic brand usually fits most all machines. :)
Jan 17, 2009 | Kenmore 15212 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
110 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
