Question about Estate TEDX640JQ Electric Dryer
I was cleaning the lint filter and placing the debirs in an empty oatmeal box, suddenly the top flew down the dryer vent shoot. I could not retrieve it. What can I do?
  • Estate Master
  • 7,482 Answers
Disconnect your vent hose from the dryer and remove the top of the box.
You may have to disconnect it from both ends to get it out if it is in the hose, do not leave it in there as it could cause the dryer to overheat and catch on fire.
If it is still in the machine then remove the back of the dryer and locate the blower, remove the blower and it should be there.
You can turn the dryer on momentarly then right back off to **** the paper lid to the blower.
This is a Free answer, Please rate me
Posted on Oct 03, 2010
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
The tumble dryer bip and flash "empty water" even if no water. I have cleaned every filter (2 inside the big filter at the bottom of the tumble dryer) but still have the trouble
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
4.Check tumble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Sep 27, 2008 | LG Dryers
WHIRLPOOL DRYER WILL NOT TURN ON, MODEL # LER2614BW1
your lint filter is on top so all your parts are in the back,you'll need a meter to read out some parts,usually the sryer hasn't been cleaned out,the lint backs up,the dryer runs to hot and one of the t-stats or thermal fuse pops as a safety so unplug the dryer,pull out the lint filter and remove the two phillips screws in front of it on the top panel,pull out the dryer,remove the vent line and the back panel,now on the left side you'll see the metal duct that the lint filter slides down into,to the right of it and down low you'll see a white plastic piece,thats the thermal fuse,pull off at least one of the wires and check it with your meter for continuity,if it's good go to the right side and you'll see the heater box,check the t-stats on the box,the top one,this is a kit a 279769,you change out the top and bottom t-stats,like i say you have to pull off at least one of the two wires or both to check for continuity.now you have to clean out the dryer and vent line or it will happen again,go back to the left side,remove the metal duct by taking out the 4 screws and you already removed the two phillips screws on top in front of the filter,pull it out and clean the duct,shop vac is the best,you can stick the hose on the other end of vac and it will blow,blow out the blower wheel,the heater box just blow off the whole back of dryer to get all the lint out,put it back together but not the top two screws,now if the vent line is long i use a leaf blower and blow out the vent line with it,first go outside and make sure the duct is clear,no cage or screen,if anything is there remove it and don't put it back,all it will do is collect lint,now go back inside stick the leaf blower into the vent line and blow it out,have someone outside to check if it's blowing out,sometimes you need to use brushes if it's hard pipe to clean it out if it hasn't been done for years,now put the dryer back in place and remove the front panel and clean that out,i'll send a video to show you how,also i'm sending you a video,it's about the high limit t-stat on your heater box,i've done this a number of times to reset the t-stat and it works hope it saves you a few bucks,
http://www.youtube.com/watch?v=UuFQOuSlzlw
Jan 11, 2014 | Dryers
There is lint down in the "basin" below the lint filters and I cannot reach it to vacuum it out. I empty the lint screens after each and every load but this has built up in the bottom in the stainles
unplug it,remove the bottom panel,pull out the lint filter,you'll see the metal duct that the lint filter slides into,remove the 1/4 inch screws that hold it in place and remove it and vac it out,if you have a shop vac you can blow the lint off of the motor and blow all the lint in the back of the cabinet forwards and then vac it up,this way you don't have to pull the dryer apart to clean it,you should do this once a year so you don't have any problems with the dryer and your clothes will dry on time,also you should clean out the vent line,pull out the dryer,remove the vent line,if it's a long run stick a leaf blower into the vent line and blow all the lint in it outside,first make sure you don't have a cage or anything that will catch the lint,if you do remove it and don't put it back then go inside and blow out the line.this happens to every dryer even if you clean the lint filter every time.hope this helps and good luck with your dryer
Mar 30, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
No heat
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The dryer is running but no heat
Hi
Feb 02, 2011 | Samsung Dryers
My dryer is working but there is no heat coming out
First place to look is to check if the "overheat" contact or the heater element has blown.
Feb 01, 2011 | Hotpoint Dryers
How do I get the top off my dryer to retrieve something that is down by the drumm . The back is already off for cleaning.
if it has lint filter on top, remove 2 screws in filter housing , pull top forward and lift. if no lint filter on top, use paint scraper to disengage clips about 2 inches in on either side between top and front panel in front of machine..
Jul 24, 2010 | Kenmore 62602 Electric Dryer
A sock fell into the lint resevoir; how do I remove it?
If your dryer is the model you have this listed under (lint filter on the top panel), then retrieving something stuck in the vent is pretty simple. Just follow these steps:
1. Unplug the dryer and remove the back panel. The dryer exhaust vent is located on the left hand side (as viewed from the rear).
2. Remove the screws that hold the vent in place and remove. NOTE: Make sure you remove the two screws located on the top panel as well. The entire exhaust vent will come out.
If this is not how your dryer is configured, please post back with your correct model number. If you have any questions, please let me know. I hope this helps you.
Mar 31, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Noise from the lint vent
idf top mount filter remove screws under filter lid remove nback cover remove 4 screws holding cover and lint housing to back pull housing down and out ..something may be hitting wheel just clean and reassemble ..on inside door filter remove bottom cove remove filter remove screws holding filter/blower cover in place ckd for smae objects clean and reassemble
Sep 02, 2008 | Kenmore 63012 Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
