Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer stop working
Yesterday i was listening to my system and i had no problem everything sounded the normal but when i stop by my house and went back out to my car to leave again i had no sounds coming out of my subwoofer i took the woofers out of the box and i dont see any physical damage
  • fitbmxrider1 Jul 16, 2008
    i was just driving down the road listen to my sub whe all of the sudden it stopped working i thought some wires came loose but when i check everything there seemed to be nothing loose or wrong with it. Everything was check and i can not figure out why my sub is not working. Whats Wrong?
Push down on the speaker, does it make a ruff nosie? if so the speakers voice coil is blowin. did ya check the amp to the subs?
could be a lot of things . check the amp make sure it has power,
do u have an in line fuse? if so check that ,to make sure it aint blowin
Posted on May 26, 2008
SOURCE:
06 Colbalt Electrical System Dead
I would go to the positive terminal on the battery anjd check for black hard build up on the post and inside the terminal. This is lead sulphate and cause a high resistance to any high current flow. Clean both with sand paper until shiny and refit and tension properly. Do the negative also as it will have build up but to a lesser degree. If the battery lead runs through a connection box Check for tight connections there also. As to towing most towers have a wheel rack that fits under the tyres and lifts them clear of the road so it can be taken to to a shop.
Feb 17, 2013 | 2006 Chevrolet Cobalt
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Car was working fine then i went out again it started then cut off and now won't start everything's fine only thing went wrong power windows stopped and power windows stopped working also before...
Sounds like possible fusible link is blown or lose?
Fusible links are different then regular fuses found in fuse box and are located under the hood near the battery ..
Did you just install the system ? or has system already been installed for a while and this problem just occurred ?
May 15, 2011 | Car Audio & Video
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
Two 10" Rockford Fosgate P1 subwoofers stopped making sound
Sounds like you've blown them.
When you were playing back to the friend, were you playing louder than usual?
Was the old box ported, and the new one sealed? The lack of ventilation may have caused the blow...
Jan 12, 2010 | JBL GT150 Car Subwoofer
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
The sound stopped working on my koss KS2503. Yesterday everything worked perfectly fine. Today there is no sound. Everything else seems to work. I checked all the connections and have had no success. Is...
unplugg your tuner from the AC wall outlet then check the setting on the tuner do not try to watch and listen to the tv only try to listen to the radio or a CD and select the right option on the tuner to do so. If you have sound on any of the functions....radio or CD/MP3 then the problem lies on the setting not correct for the TV/VCR/DVD mode.
Sep 12, 2009 | Koss KS2503 System
No sound from right front satelite
sounds like you have blown speaker swop them over and see if it works, if so you need repair shop
Sep 29, 2017 | Mission FS2-AV System
I'm not sure how to set up my LG HT762TZ home theatre system up properly. I have connected everything and made sure it is working properly, but i am not sure where to put the speakers and which way to put...
The rear speakers are meant to be placed at the rear preferrably overhead or at the bottom behind your listening area. Both speakers should be facing the sides. You can place your subwoofer anywhere as its sound is non directional. Don't forget to adjust its volume properly, the rear should not overwhilme the front/center sound. Happy Listening
Mar 27, 2008 | Audio Players & Recorders
Soundsticks 2
hows the control vol in windows all way up meada player settings is it pluged in all way turn down master then back up reboot comp
Jan 05, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
64 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
