Its kinda weird if i pull the battery out then put back in it turns on automaticly then right back offf then wont do anything after that
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
Change the mainboard
Posted on Oct 03, 2010
What do i need to do?
Never use a phone before it dries out completely. Take out the battery and put the phone and battery in a bag of uncooked rice for a day or two to get it dry, then put the battery back in, turn it on and hope.
Jun 19, 2015 | Blu Studio 5.0 Mobile Phone
How do I open my trunk after I take the battery out. I have no power and the key wont open the trunk.
In most cars you're able to fold down the back seats once you do that you can kinda slide into it and pull the Manuel trunk release should be a pull cord of some type (not all cars will have it) but worth a shot
Apr 09, 2015 | Cars & Trucks
I phone wont turn on
Remove your battery and try again
Jul 09, 2012 | Apple iPhone 4 Black Smartphone
Replaced battery and display says running but is frozen. wont do anything including turn on or offf
Having received no response in over a month, I assume the suggested reset solved the problem.
Aug 10, 2010 | HP 12c Calculator
LG enV2 wont get past the black screen with the verizon logo
put a battery on it turnit on off on offf,,,,,if not throw it away!!!!!!!!!!!!
May 31, 2009 | LG enV VX9900 Cellular Phone
1999 dodge diesel wont start
It sounds to me that you may have a dead cell in the battery you didn't replace. When replacing batteries that are paired up it's better to replace them both at the same time. The same as you would a set of brakes. That's because if you have two batteries wired together and one of them is weak,( bad cell, smaller cranking power, etc.) it will draw down the other battery untill they are equill. The smoke you are seeing coming from the other battery is more than likely from a bad connection. It could be from a loose connection, it could be corroded, it could be that it is not recieving a charge back to the batteries because of that bad connection. I'd clean the connections and make sure the terminal ends are in good shape. Pull the battery caps and check the water level. If it's low you probably have a shorted cell. You can attempt to remidy this for awhile by adding water and charging the batteries back up. REMEMBER, if you add water, only add distilled water. You can get this just about anywhere including your local grocery store. Also when charging a battery take the battery caps off while the battery charger is running. Good luck, and let me know if this helps or you have other problems.
Mar 29, 2009 | 1999 Dodge Ram
Wont start again after driving
have somene try to start the car while you listen under the hood for the weird sound of something spinning it kinda sound like something griding. sometimes it occurs 2 to 3 seconds after turning the key. if you hear that sound then it's your starter i just had the same problem about a day ago . it's easy to fix i took mine out and had it rebuilt for 55 bucks reinstaled it and it started right up. here's a that will guide you through the repairing process.. http://www.cardomain.com/ride/2076435
Jan 20, 2009 | 2000 Nissan Maxima
Right front fork seal bad? Oil mess
got away from rear break usage due to weird squealing which I've read about. The book says to use front brake as much as possible but puts downward load on front shocks alot. Damn Injuns. Sorry for the vent its a putter but the wife is asking why is it apart more than on the road. The wife I can fix the bike I need help.I'd replace the O-ring on the cap on top of the fork tube first. The turn signal is kinda high to be getting oil on it from a fork seal leaking.,,
Nov 10, 2008 | 2006 Enfield Bullet Machismo
98 accord wont start. lights flicker in dash and engine wont turn over
Have the battery checked.  You may have heard a fast clicking sound when the lights were flickering, if so it's coming from the starter solenoid.  If the battery is bad, have the voltage regulator and alternator checked also.  A bad voltage regulator or alternator will kill the new battery.
Try starting with jumper cables, if that works, you can pull the battery out, take it to a auto parts store that will test it for free (most parts stores will do this).  If it's bad, you can put a new battery in and then drive straight to somewhere to have the charging system tested.
Oct 31, 2008 | 1998 Honda Accord
Camera wont come out of Close up Mode!!
The case is probably warped, and keeping the close-up button depressed.
Jun 21, 2008 | Kodak EasyShare C643 Digital Camera
Computers & Internet Logo
David Payne
David Payne
