Question about GE Refrigerators
Even though both doors are closed, the door alarm keeps beeping. And beeping. And beeping. It seems to be connected to the bottom freezer--when ice or frost builds up it interferes with the switch on the inside. If I turn the frig off overnight, it seems to take care of it for a few days. On the advice of the last repairman who saw it, I occasionally add a layer of petroleum jelly to the rubber seal. Any ideas?
    Genius:
  • 1,478 Answers
You will need to replace the defrost timer, A mechanical defrost timer controls the defrost cycle of the freezer. In older models, the timer runs continuously and roughly every six hours, cuts power to the cooling system and sends power to the defrost heater. In newer models the timer advances only while the compressor or defrost cycle is running - an improvement for efficiency. As the timer continues to advance, power to the heating element is cut and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Take care.
Posted on Oct 02, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Since hours I hear 3 short beeps - no open door alarm., No error code.
This model has trouble with ice building up behind the freezer doors preventing them from closing all the way. You may need to defrost.
Nov 05, 2015 | LG 24.7 cu. ft. French-Door Bottom-Freezer...
The alarm dings. Why does the ice/water dispenser then shut off and lock?
Not sure if I'm reading this right. Is the alarm you are talking about the one that tells you the door is not closed all the way??? If that is correct, then the reason your ice/water system is not working is because the wiring system for the dispenser is fed through a switch on the freezer door which keeps the dispenser off when the door is opened. You need to correct the door problem causing the alarm to ding and that should also fix the dispenser problem. Possibly a door adjustment needed. Door top edges should be aligned and even across the top and the gap between the doors should also be the same distance top to bottom if this is a side x side.
Mar 21, 2015 | GE Refrigerators
There is ice forming on the inside back wall of the freezer. What does this mean? Would it cause the refrigerator alarm (beeping noise) to go off?
It usually means that your door is either not closing properly or the seal is deformed. Moist air is getting in and condenses on the coldest surface at the back of the freezer. Check that the freezer is not too full (stopping door from closing fully) and check the door-seal.
Sometimes it is caused by icing of the thermostat. Ice is a good thermal insulator so the thermostat does not switch and the freezer keeps running constantly. Make sure there is adequate air circulation and no ice around the thermostat.
Defrosting usually fixes either problem.
Oct 13, 2014 | Refrigerators
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Kenmore elite refrigerator alarm keeps going off even though the doors are closed
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
Nov 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Aug 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
