Question about NEC Electra Elite DTU 16D-2 Corded Phone
How do i clear the dnd function on my nec phone
SOURCE: taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
Posted on Jun 17, 2008
bhur
  • 85 Answers
SOURCE: cant turn off dnd on
need to reflashing your phone.
Posted on Jul 19, 2008
SOURCE: NEC phone
CLICK THE DND BUTTON ONCE, GIVE IT A FEW SECS AND IT SHOULD GO OFF.
Posted on Oct 29, 2008
  • 149 Answers
SOURCE: How do you remove the DND feature on phone model NEC Dterm Series III?
Feature 69 feature.
Posted on Nov 13, 2008
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
DND on Nec phone not working. I still get the calls in
Likely the button your pushing is just a speeddial button with the DND code, which somehow has been erased. Don't know which of the 12 or more NEC systems u have, but someone should have the user guide to reprogram.
Apr 20, 2016 | NEC Lands Phones
How do I get the phone off DND mode
A common problem on the NEC Electra/Elite phone system is that users will pick up the phone and start dialing numbers while hearing intercom dialtone which sounds identical to outside line dialtone. If the user dials 4 then 0, DND is set on that phone ext. The easy way to clear this problem is to go to the phone that is in DND, lift the handset or press speaker and dial 4 then 2. You should get a confirmation tone after which you can just hang up.
Jun 05, 2011 | NEC DTH-8D-1 Corded Phone
My feature key is lite and I have DND. How do I get this to cancel
Remove the Line wire from the back of the phone and then plug it in again. See if the DND function is still on. If yes : pick up the handset or press Speaker key and then press the corresponding DND Softkey (the buttons right under the LCD). If you don't see any DND text on the LCD of the phone try to move to another pair of Softkeys by pressing the last button (see the >> on the LCD)
Mar 17, 2011 | NEC DTH-8D-1 Corded Phone
Pls help to solve my problem NEC telephone IP2Ap-6TXD I set to DND external, how can i deactivate it please..
Feb 01, 2011 | NEC Dterm DTP-2DT-1 Phone
DND causing line to go busy when on call for new incoming callers
Please contact your local NEC dealer and have them program the phone to go to voicemail when in DND or when Busy
Mar 20, 2009 | NEC-1090021 DSX 34-Button Backlit Display...
Function
If your main system cabinet (in some closet somewhere) is plastic, you have the NEC Electra Professional Level I system and the DND cancel procedure is <FNC>, 60, <FNC> when the phone is idle. If your main system cabinet is metal, you have the NEC Electra Professional Level II system and the DND cancel procedure is <FNC>, 69, <FNC> when the phone is idle. You can also press "42" while hearing intercom dial tone. The most common cause of accidentally setting DND is by dialing "40" while hearing intercom dial tone (Level II system).There is a slim chance your main system is not the Electra Professional series. If either of the above do not work, let me know.
Jan 15, 2009 | NEC ETW 16DC-1 Corded Phone
Nec dterm80
Another solution is to pick up on intercom and dial 4 then 2 and hang up. That is the default DND cancel code. It can be used form single line phones within the system as well.
Oct 03, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
463 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
