Question about Epson Stylus Photo R1800 InkJet Printer
Epson stylus photo R1800 printer
Top 2 lights are flashing red paper jam button and ink button but no green button cannot get the printer to start again
  • 12 more comments
  • nelly01 Jun 04, 2008
    top 2 lights are flashing red paper jam button and ink button but no green button cannot get the printer to start again. Can anyone help??
  • jmnct Jun 25, 2008
    I have same problem: two alternating, flashing red lights and no green light. Cartridge carrier seems locked in place.
  • homern Jul 13, 2008
    My printer cartridge is jammed, then a terrible noise, then the top light flashes.
  • impresoslabr Jul 18, 2008
    parpadea las dos luces de papel y tinta ¿que hago? R1800
  • mikets Jul 27, 2008
    Both ink and paper light are flashing one after the other.
  • jktillery1 Aug 22, 2008
    cleaned the felt pad in my epson r1800 but the top two lights are still blinking Is there another step thanks for any help
  • artist71 Sep 04, 2008
    help! paper and ink lights (red) are alternately flashing.I have had endless difficulties with the heads requiring cleaning - used magic bullet which helped and it was just beginning to work corrrectly -Whats happened?I can't even get green light to come on.
  • Anonymous Jan 22, 2009
  • ETHEL PATTERSON Feb 08, 2009
    power button goes off straight away but paper and ink button flash red after each other
    HI
    I HAVE AN EPSON R1800 ABOUT 9 MONTHS OLD USING CIS PIGMENT INK
    I HAVE JUST RFILLED ALL INKS AND RAN A COUPLE OF CLEANING CYCLES
    ALL OF A SUDDEN WITHOUT ANY ERROR MESSAGES
    THE PAPER AND INK LIGHTS STARTED FLASHING RED AND THE GREEN POWER LIGHT SWITCHES OFF IMMEDIATLEY AFTER SWITCHING ON
    I HAVE GOT A SERVICE REPAIR FACIITY BUT CAN'T USE BECAUSE POWER LIGHT SWITCHES OFF IT "JUST SAYS PRINTER SWITCHED OFF OR SOME OTHER PROBLEM "
    CAN ANYONE HELP ?
    THANKS
  • Anonymous Feb 11, 2009
    accendendo la stampante si accendono le spie della carta e dei colori lampeggiando insieme rossi e contemporaneamente si spenge l'interruttore della stessa ma loro continuano a lampèeggiare
  • Anonymous Mar 17, 2014
    Epson stylus photo t60 paper light and ink light blinking error
  • Anonymous Mar 28, 2014
    I put the paper in the slot and it just doesn't catch for some reason.
    Can't take the jam paper out
Http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Hi my R1800 has 2 flashing red lights (top) and no power light. What can i do? MAria
Hi.
It could be your ink tray has overflowed.
There is software http://www.ssclg.com/epsone.shtml which might help.
Install this program, set your printer model and the driver (Epson Stylus Photo R1800) when it starts up. Close the program, and it will minimize to the
tray on the taskbar - right click on the icon and goto "Protection Counter". Choose
"Reset Protection Counter". Choose "Yes" to the question about the waste ink pads,
then switch the printer off for 1 minute. This should cure the problem.
It might be worth a try
Jun 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
R1800 service required
Martin,
Did you ever find a solution. I was away for a month and just tried to use my epson photo R1800 and the same thing happened to me....flashing lights and a "service required" note. Before I left it worked fine.
Jun 06, 2009 | Epson Stylus Photo R1800 InkJet Printer
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson R230
If that is the case?
Here is the solution.
Ask your reseller to give you a reseter software.
Maybe because the printer exceeded to it duty cycle.
Duty cycle is printouts maybe about 5000 printouts
Jun 15, 2008 | Epson Stylus Photo R200 InkJet Printer
R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Oct 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus photo r1800
Return it to them. If it is under warranty, they should replace it.
Oct 06, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
1,505 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
