Question about Dell Inspiron E1505 Notebook
My Inspiron 1505 will not type the letters h,t,c and e in e-mail only unless I put on the cap lock then hit the shift key. Any ideas what the problem is?
    Master:
  • 397 Answers
The potential is you have what's known as "sticky keys" turned on. Check accessibility options and make certain it is turned off. Those letters are used as shortcuts for various actions in different email programs- I suspect sticky keys is the problem.
Posted on Oct 02, 2010
Testimonial: "I think this may have worked. Although sticky keys were not engaged, I cycled it a few times and the keys now seem to work. Thanks"
CAPS LOCK DOESNT UNLOCK
if you hold down the Shift key and type are the letters small??
sounds like your Caps Lock key is stuck
Nov 02, 2017 | Computers & Internet
Tip
Quick and painless CAPS LOCK
<span> Are you one of those people that likes to yell on the internet while you post on forums or chat with others? You know, <i>DO YOU CHAT LIKE</i> THIS? If so, (and I am sure others just love you for it) you will want to use the <b>CAPS LOCK trick</b>. Normally, when you type with the <b>iPad's </b>onscreen keyboard you have to hit the shift key and then the letter to get a capital. You then have to do it again for each letter in the word. To bypass this, just tap twice on one of the shift keys, and you will now have <b>CAPS LOCK</b> for the whole word. This will save you a lot of time and frustration without having to hit the shift key repeatedly while typing.<br /></span>
on Dec 19, 2010 | Cell Phones
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
HOW DO I CONNECT MY APPLE IPHONE TO PLUSNET WIRELESS
To type capital letters, press the shift key which is the up arrow in the bottom left corner of the screen, and then press the key for your desired letter. If you would like caps lock, double-tap the shift key. Note that the caps lock will be deactivated if you change to the number keyboard or symbol keyboard.
Jun 23, 2012 | Apple iPhone (16 GB) Smartphone
Have entered the proper id and password however won't let me open my e mail
Do you have caps lock on? Are you sure you are putting the correct letters capitalized, or are holding down shift while trying to type numbers. Maybe not holding shift to type characters.
Jul 21, 2011 | Yahoo Mail
How to change the uppercase and lowercase letters
Either by pressing and holding the shift key (on left and right of keyboard, looks like up arrow) while typing, or by pressing the CAPS LOCK key to put capitals on or off. The caps lock key is usually one above the left shift key.
If you cant find them just advise your make and model of computer and I could tell you exactly where the keys are.
Oct 31, 2010 | Computers & Internet
Password
Check caps lock, if your on a laptop make sure num lock is off hit num lock and try again, num lock will incorporate numbers with the letters because there is no 10 key keypad on most laptops. Also check that shift key is not stuck tap each shift key twice then try again.
May 21, 2010 | Yahoo Mail
Keyboard locks into all CAPS
Just a thought...one time I had a button that kept stiking itself with out me touching it...I removed the keys aroud it, only to find a tooth pick had found its way into my keyboard. Everytime I would hit any of the keys around it, it would also hit that button too. Dont know if this is your problem but worth a look!!
Sep 18, 2009 | HP D8597A Keyboard
Dell Inspiron E1505 Notebook Logo
102 people viewed this question
Alun Cox
