Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load washing machine has code of ue
SOURCE: Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Posted on Oct 28, 2006
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
  • 240 Answers
SOURCE: F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
Posted on Jun 03, 2008
  • 188 Answers
SOURCE: iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Posted on Feb 19, 2009
canbruce75
  • 1776 Answers
SOURCE: F35 error code on a kenmore Elite front loading washing machine
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Posted on Sep 09, 2009
How to clear a UE code on Kenmore front load washer
it mean ou have unbalance load it you washer an small load try add more item are if you washer an heavy load try reduce load an make suer your washer is level it the porblem continue may have replace timer
Dec 13, 2017 | Kenmore Washing Machines
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore elite will not finish a wash. every load no matter the size has a UE code. Please advise.
the ue code indicates that the control detects an unbalanced load in the washer that cannot be redistributed. press the start/pause button and try to redistribute the load. here are some problems that can cause this error code
the washer is not level or not stable. make sure that the washer is leveled properly front to back and side to side. press down on opposing corners to make sure that all 4 feet are firmly on the floor. adjust the leveling legs if necessary.
WASHING TO SMALL A LOAD
laundry can sometimes gather to one side. redistributing the load manually can resolve this issue.
try running the washer without any items added and see if it will spin properly. if not, you could have a problem with the control board or the hall sensor on the motor that detects motor speed.
May 17, 2015 | Kenmore Washing Machines
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
Front of wash displays UE code
Hi
Code UE is an unbalanced load error, usually shown when there is a very small load where the machine cannot redistribute the weight to balance it .Either the load is too small, the appliance is tilted, laundry is gathered to one side, or non-distributable things have been put into the machine.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | LG WM2301HW Front Load Washer
Code UE
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
LE (with a a slash in the
middle of L. Thermister out
CE: Over amping
LE: hall sensor short
bE: Ball sensor loose connection
EE: eeprom out
PF: power failure
Service manuals for LG front loaders
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 26, 2010 | Kenmore Elite 45986 Front Load Washer
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
447 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
